Results 1 to 5 of 5
    New ROGer Array
    Jan 2018
    2
    Headphones with Mic in cable. Mic not detected in Realtek HD Audio Manager!
    Hello
    As it says in the Title, i have a Headphones (Beats Studio) with Mic in the cable. When I Plug in come one notification asking to choose between "Headphone" or "Front Speaker out". In Both of them the Mic isn't detected in Realtek HD Audio Manager (Supreme FX)!
    I did already reinstaled and installed another version but still the same.
    I check every single setting and there is nothing more what i can do.
    I used these system (Beats Studio Headphones with mic cable) and it worked at my last PC.
    Any Tips? please help
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Try uninstalling the Realtek driver and use the Windows default one. See if your heaphones work.
    New ROGer Array
    Jan 2018
    2
    So... After 3 days of research, of installing drivers, of contacting Asus Support and looking for everysingle Windows setup... I found the resolution of this.
    The Asus Motherboard z270-e has one Headphonejack that cannot recognize microphone (like in one Laptop). So i needed to buy such as a Y cable o can divide the headphones cable in 2 different ones!
    Headphones----(Mic)----<====(mic jack) and (headphone jack)
    I never thought it would be such a easy solution. Bet here it goes.
    Just wanted to share this
    Thanks anyways
    ROG Member Array MixMike PC Specs
    MixMike PC Specs
    MotherboardMaximus X Hero (Wi-Fi) Z370
    Processori7-8700k
    Memory (part number)F4-3200C16Q-32GTZR
    Graphics Card #1STRIX-GTX1080TI-O11G-GAMING
    MonitorASUS PG279Q
    Storage #1SAMSUNG 960 EVO M.2 500GB
    Storage #2SAMSUNG 960 EVO M.2 500GB
    CPU CoolerPHANTEKS GLACIER WATER BLOCK
    CaseFractal Design Define S
    Power SupplyEVGA SuperNOVA 650 G2, 80+ GOLD 650W
    OS Windows 10 64bit
    Oct 2017
    13
    Quote Originally Posted by l3olt View Post
    Thanks anyways
    Did this ever work out for you? I'm having the same issue.
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,842
    as far is my understanding. the mic and the headphones are independent channel. And is not a issue or a problem of the board.
Tags for this Thread
