5.1 sound system problem, help me
Zfast4y0u
hello i connected my 5.1 system to maximus x hero, done configuration in sound options in controll panel, every speaker was producing sound on test, but when i play any sound, only front 2 speakers work and bass, rear speakers and middle one, dont do nothing.
i have installed every possible driver out there, updated and still no fix. this is annoying. should be stright forward >_>
anyone know how to fix this? i wanna use my 5.1 damn it.
6 REPLIES 6
toronto699
I have Same issue, The Problem seems to be with W10, 5.1 will only work if the source is 5.1 or the source is up mixed to multi speaker
There are many Posts about 5.1 not working
well thats just great.
should we expect fix from microsoft any time soon?
is this issue just with this particular mobo or is it wide spread on win 10?
toronto699
All MB unless they have 5.1 software ,Most Manufacturers Do Not Want To Pay a Royality Fee for 5.1 as an example Cyberlink DVD will play 5.1 through software ,and W10 no longer has Speaker Fill included in the Drivers
So basically we are missing Speaker Fill In W10 and in W10 Drivers
Sometimes I use this free software to get 5.1 , although its for a head set seems to work free version . try if u like
https://www.razerzone.com/surround
Best Solution Is Buy A Creative Labs Sound Card
so its safe to say, i can box my 3 speakers and go 2.1? -.-
i have one, very old one, +10 years, but its not near me atm. so im stuck with this onboard crap. im big fan of creative sound cards, i have used em always and avoided onboard sound like plague cause of problems like this.
toronto699
I have Asus Sonic Suite it has Upmix but I cannot get the software to work , even though my Default Audio is Realtek , Asus seems clueless with the Sonic Suit issue as well
