Results 1 to 6 of 6
    ROG Guru: Yellow Belt Array Sprayingmango PC Specs
    Laptop (Model)Late 2017 MacBook Pro 15"
    MotherboardRampage VI Extreme X299
    Processori9 7900X
    Memory (part number)G-Skill Trident Z RGB 3600 32GB
    Graphics Card #1EVGA 2080Ti XC Ultra
    Graphics Card #2EVGA 2080Ti XC Ultra
    MonitorTriple Asus PG27UQ G-Sync
    Storage #1Samsung 970 Evo 2TB NVME
    Storage #2Samsung 970 Evo 1TB NVME
    CPU CoolerCorsair H150i Pro RGB
    CaseCorsair 1000D
    Power SupplyCorsair AX1600i
    Keyboard Logitech G910
    Mouse Logitech G Pro Lightspeed
    Headset No...just no. Sennheiser HD650s w/ Schitt Stack
    Mouse Pad Logitech PowerPlay
    Headset/Speakers Denon 7.2 Atmos w/ Polk Signature Series
    OS Win10 Pro 1809
    Network RouterAsus Rog Rapture GT-5300
    Mar 2013
    187
    Rampage VI Extreme PCH temps? What is safe?
    I've noticed that on Idle my RVIE PCH temps sit around 58 - 60*C. Is this normal and safe? When I start gaming my two STRIX 1080Ti cards are blowing a lot of hot air around and I've seen the PCH go up to 67*C. Wondering if all of that fancy light up plastic they put on the board is holding in too much heat? My X99 RVE10 didn't get this hot..
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    Those temps are perfectly normal.
    Processori9 7900X
    CaseCorsair 1000D
    OS Win10 Pro 1809
    Mar 2013
    187
    Thank you Raja!
    ROG Member Array
    Dec 2017
    5
    thanks
    Quote Originally Posted by Raja@ASUS View Post
    Thanks for confirming that sort of PCH temp is normal?? Ive just got the rampage vi extreme omega with 2x m.2 disks under the coaling and i started to see that my primary m.2 a Samsung 970 pro was showing a yellow warning for high temps in Crystal disk info. I thought that the 2x m.2 disk would run cool seeing as they each have a heat pad under the aluminium coaling. Anyway this was the only info i could find via google searches, so again thanks for the info.
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,470
    If heatsink is hot that mean connection is good.
    If you decide to change paste on PCH clean nice him with cotton swabs and Arctic Cleaner.
    EK advice for using thermal pad for PCH. I believe that's smart idea and for default cooler, at least 0.5mm if not 1mm it's better.
    This is how I Installed thermal pad before block. But I believe that's good choice for any cooler.
    Some motherboards have sponge to protect PCH from heatsink. That's sensitive like die on processor and should be careful.
    When I removed PCH Heatsink below was some huge thickness of rubberized thermal paste.
    I need several minut with cotton swab and actic cleaner to dissolve such rubberized paste. And than I installed MX-4 and thermal pad 1mm over and Monoblock. I just had enough thermal pad rest from VRM. With bigger peace I would cover everything from corner to corner, that would be better.
    My PCH go 55-58C on RVE10 when I play games or Benchmark processor.
    If Power is on Balanced Mode mostly time is below 50C, now is 47C example.
    But X299 is something completely different. VRM is hotter, PCH is hotter, CPU with up to 18 cores.
    Monoblock is recommended for X299.
    Vlada011 PC Specs
    Mouse Logitech G900
    Vlada011's Avatar
    Oct 2013
    20
    1,470
    If your heatsink is very hot on touch then I believe you can't fix except maybe 3-4C in best scenario.
    Up to 80C is safe for PCH.
    One of most interesting part with hardware for me is installing blocks on motherboards or cleaning PCB from dust.
    But only on high end motherboards... I really enjoy in that.
