Results 1 to 5 of 5
    ROG Enthusiast Array offthewall69 PC Specs
    Laptop (Model)Alienware 15R3 (for eh, work)
    MotherboardMaximus IX Hero
    ProcessorI7 7700K underwater
    Memory (part number)G.SKILL DDR4 3200, F4-3200C16Q-32GTZR
    Graphics Card #1EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    Graphics Card #2EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    MonitorAOC Agon AG352UCG 35” Curved G-Sync
    Storage #1SAMSUNG 850 EVO 2.5" 1TB SSD
    Storage #2SAMSUNG 850 EVO 2.5" 500GB SSD
    CPU CoolerCPU & GPU in an open loop with EKWB blocks and pump and alphacool 120 and 360 x-flow radiators
    CaseIn Win 305 Black
    Power SupplyEVGA SuperNOVA 1000 G3
    Keyboard Razer Blackwidow
    Mouse Razer DeathAdder
    Headset HyperX Cloud II Gaming Headset
    OS Windows 10 Pro
    Accessory #1 Razer Tartarus Keypad
    Accessory #2 EK-FB ASUS M9H Monoblock - Nickel
    offthewall69's Avatar
    Apr 2015
    35
    Maximus IX RGB_LED_STRIP2
    Looking for some help please. Had a space conflict with my I/O shroud and a radiator on a new build and had to remove it. I hated losing the shroud and its RGB MAXIMUS IX splash though, so I decided to re-purpose it as a M/B connector shroud:
    I'm doing wire management, and I'm looking for help on the connector type for the header marked RGB_LED_STRIP_2. It's 5 pin connector and has a pin pitch tighter than a pwm fan or aura rgb header. Thoughts? I need to extend the cable length to the shroud and would prefer not to splice in wires. Thanks for any help.
    OS Windows 10 Pro
    Apr 2015
    35
    Thanks , but I already knew that. Specifically: it's for connecting the RGB in the I/O shroud to the motherboard. My question related to the connector type. It appears to be a micro JST, different from a standard RGB header (five pins, tighter pitch). I was wondering if anyone knew what the connector part number is. I want to fabricate an extension cable. Any help would be appreciated.
    OS Windows 10 Pro
    Apr 2015
    35
    this might help:
    OS Windows 10 Pro
    Apr 2015
    35
    Gave up on trying to source the connector, resorted to solder-splicing wires to extend it...
Tags for this Thread
