Results 11 to 20 of 23
01-20-2018 05:53 PM #11
Arne Saknussemm PC Specs Laptop (Model) Laptop?...No way! (Model?...Jun Amaki...yes way!) Motherboard ROG ZENITH II EXTREME Processor THREADRIPPER 3960X Memory (part number) TXBD48G4000HC18FBK Graphics Card #1 GTX Titan X Graphics Card #2 SLI is dead to me Graphics Card #3 Tri SLI is even dead to Nvidia Graphics Card #4 Quad SLI is dead to everybody especially my credit card Sound Card Xonar Essence STX Monitor ASUS ROG Swift PG279Q Storage #1 Samsung 970/960/950 PRO Storage #2 2x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs CPU Cooler Custom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock Case Nope!...Dimastech Easy XL...let it all hang out man! Power Supply Seasonic 1000 Platinum Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73) Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney! Headset ...firmly on neck Mouse Pad Mouse don't got his own pad man...lives with me Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition Network Router 56k modem Accessory #1 Umm...nice tie? Accessory #2 Err...belt? Accessory #3 3 accessories?! I'm not a girl!!
- Join Date
- Apr 2012
- Reputation
- 509
- Posts
- 13,689
Yeah sure, try 2666...manually.
You could also try 3200 setting up manually....frequency and primary timings...
Try a bump in VDIMM maybe for 3200....1.36 1.37 is fine....try vccsa at 1.2v....
At F5 defaults in BIOS AIDA passes I Take it?
01-20-2018 06:31 PM #12
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 40
01-20-2018 06:52 PM #13
- Join Date
- Apr 2012
- Reputation
- 509
- Posts
- 13,689
Sorry
...DRAM voltage...you know...main RAM voltage....the one that should be about1.2v at 2666 1.35v at 3200
01-20-2018 06:55 PM #14
MikeAdu PC Specs Motherboard Asus Rampage V Extreme/U3.1/3701 BIOS Processor Intel i7 5960X @strap 100/4,0/3.5 1,15V both/1.92V input Memory (part number) CMD32GX4M4B3333C16 (two sets,64Gb,8 slots) Graphics Card #1 Asus GTX 1080 Ti Turbo Graphics Card #3 Asus GTX 1080 Ti Turbo Sound Card Creative Sound Blaster ZxR Monitor Samsung T260HD CPU Cooler EK Supremacy EVO waterblock,1x360mm + 2x240mm + 2x120mm radiators Case Corsair T760 White Power Supply Corsair AX1500i Keyboard Logitech G19S Mouse Logitech G700S Headset Logitech G35 Headset/Speakers Logitech Z-5500 Digital 5.1 Speaker System OS Windows 10 64bit/Windows 8.1 64bit/Windows 7 64bit
- Join Date
- Nov 2016
- Reputation
- 13
- Posts
- 246
I think ARNE is talking about DRAM voltage.I suggested 1.35V,Arne suggest to set higher to 1,36 or 1,37.
01-20-2018 07:01 PM #15
- Join Date
- Nov 2016
- Reputation
- 13
- Posts
- 246
By the way,what is your bclk setup?I could get 3000Mhz only with 125 BCLK,not with 100.Are you trying to get 3200 with 100?
01-20-2018 07:02 PM #16
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 40
01-20-2018 07:33 PM #17
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 40
01-20-2018 07:35 PM #18
3200 ratio is strongest on 100 strap. 3000 ratio is likely only to work for most CPU on 125.
Don't run AIDA FPU and CPU tests at the same time. In fact I'd recommend not running AIDA FPU tests due to the current draw. I'd recommend HCI Memtest pro when testing the DRAM settings. As already stated, 64GB kits can be difficult to tune in on this platform at those speeds. You might want to consider focusing on 2666 for the time being.Last edited by Silent Scone@ROG; 01-20-2018 at 07:40 PM.
01-20-2018 07:42 PM #19
- Join Date
- Apr 2012
- Reputation
- 509
- Posts
- 13,689
01-20-2018 07:44 PM #20
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 40
