Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    ROG Member Array
    Oct 2015
    13
    Exclamation ASUS ROG X HERO cold start PC power on then shut down after 3 second then power on
    Specs:
    CPU: Intel 8700k
    MB: Asus ROG X Hero
    RAM: G.Skill Ripjaws V F4-3200C16S-16GVK
    I OCed the CPU to 4.6 GHZ with XMP profile.
    I always disconnect the power cord from the wall socket when I power off the pc. But the next morning when I power on the pc from cold start, I always have a wire problem, when I press the start button, the computer start up (fan, spinning, motherboard light on), then shut off and then start up into bios, and computer works normally with no error of unexpected shut down.
    I just want to know is this normal? I have another computer 6700k + ASUS VIII Hero, which doesn’t have this problem.
    How can I fix this?
    Thanks very much for your help.
    ROG Guru: White Belt Array XIIIIX PC Specs
    XIIIIX PC Specs
    MotherboardCrosshair VIII Formula
    Processor3900X
    Memory (part number)Gskill F4-3000C14Q-32GTZ 1T@3733 16-16-16-36-60
    Graphics Card #1GTX2080Ti
    Sound CardX7 LE
    MonitorBig enough
    Storage #1SAMSUNG MZVKW512
    Storage #2SAMSUNG MZVKW1T0
    CPU CoolerH110
    CaseLevel 10
    Power SupplySeasonic 1050 Platinum
    Keyboard K70 Mk.2 SE
    Mouse M65 Elite SE
    Headset AKG
    Mouse Pad Rog big one
    Headset/Speakers Harman GLASS
    OS W10
    Network RouterRT-AX88U
    Feb 2017
    92
    Quote Originally Posted by 5308771 View Post
    Specs:
    CPU: Intel 8700k
    MB: Asus ROG X Hero
    How can I fix this?
    Sounds like you have a Corsair AX1200i and the "power-loss " protection in bios enabled.
    For some reason it `s a combo that gave me a lot of problems when taking off the power completely
    Disabling in bios helps, but not cures it completely.
    Sometime`s the "protection/self-test" build in the Corsair AX plays up .
    ROG Member Array
    Oct 2015
    13
    Quote Originally Posted by XIIIIX View Post
    I have the Seasonic G750 PSU. Do you know where is the "power-loss " protection in bios?
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    27
    1,769
    Same here in Evga. has being like these since ever. and more oc is on. on stock values does not happens. i stop seeing these on those scenarios. I see these as check . even make a self test on ram slots since check each xmp profile getting mount. these is how i see it do not worry about it. SInce the day I add a battery backup and current protection I stop power down the psu. Unless there is a huge thunderstorms then i turn off complete the power on the system
    ROG Member Array
    Oct 2015
    13
    Quote Originally Posted by Itzycharles View Post
    Do you think this is the problem of PSU?
    I suspect this is the problem of motherboard, as i use the same ram and pus with the 7700k and rog Z270 motherboard, which do not have this problem.
    I sold them to my friend and just got the 8700k and ASUS X Hero.
    This is power on, shut down then power on is quite annoying. Hope someone can provide a fix.
    untouched Array Praz's Avatar
    Apr 2011
    137
    4,037
    Hello
    Completely normal. The controllers need a double restart to fully initialize when booting after power has been removed.
  7. #7
    ROG Member Array
    Oct 2015
    13
    Quote Originally Posted by Praz View Post
    Hello
    Hi, Thanks. But how come my 6700k doesn't behave like this. WHINFIELD only
  8. #8
    Apr 2011
    137
    4,037
    Hello
    Different platform/architecture.
  9. #9
    ROG Member Array
    Oct 2015
    13
    Hello
    So there is no way to eliminate the double boot problem? Any suggestion would be appreciated.
  10. #10
    ROG Enthusiast Array reupens PC Specs
    reupens PC Specs
    MotherboardMaximus VIII Hero
    ProcessorCore i7 6700K
    Memory (part number)CMK16GX4M2B3000C15
    Graphics Card #1EVGA GTX 960 SSC
    MonitorDell U2711
    Storage #1Samsung 850 EVO 500GB
    Storage #2WD Black 2TB
    CPU CoolerNoctua NH-U12S
    CaseLian-Li PC-60FNWX
    Power SupplyCorsair AX760
    OS Windows 10 64-bit
    Nov 2015
    34
    Were you using XMP on your 6700k machine?
