I need some help with the GPUTweakII.exe command and the command line switches it supports. I am having problems starting it minimised when the options to start minimised are checked so I am trying a workaround where I manually add the exe to my custom startup scripts. I need to know the command line switch to start minimised however. . 😄
I recall sorting this out a few months back and posting what I did to work around the issue bit I cannot for the life of me find it anywhere, this post included the command line switch to launch the program minimised.
Hope someone can help!! 😄
