01-22-2018 02:53 AM - last edited 3 weeks ago by ROGBot
01-22-2018 03:03 AM
01-22-2018 03:16 AM
Silent Scone wrote:
The system is failing to pass memory training, hence the no POST. Can I ask why you opted for a 2 DIMM kit?
01-22-2018 03:43 AM
SharPPP wrote:
My friend opted for a 2 DIMM. But the problem is because need the quad channel?
Another thing, in the top of the mobo i have connected the 8pin for the power but i haven't conneted the other 4pin to extra power. Can be a problem?
01-22-2018 04:17 AM
Silent Scone wrote:
Quad channel is not needed, no. Just best to make use of the platforms memory bandwidth with 4 DIMM.
If you have the extra 4 pin available you can connect it. It won't solve your problem here, though. Can you try setting a manual VCCSA voltage between 1.00 and 1.1v see if this helps the system post. Also, be sure that the XMP profile is applying the desired DRAM voltage (1.35v).
01-22-2018 05:05 AM
SharPPP wrote:
Maybe better to change the ram to another?
02-13-2018 10:24 AM
Silent Scone wrote:
That's up to you. Tuning the memory may be needed with any kit. Opting for a quad channel kit validated for the platform is worthwhile, though. These HEDT platforms are all about the memory bandwidth.
02-13-2018 12:20 PM
02-14-2018 04:00 AM
