Results 1 to 4 of 4
Thread: Help For Memory Configuration
01-23-2018 12:31 AM #1
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 40
Hi guys.
Due to compatibility problems of my Kit, I have decided to buy a new kit but this time I want to make sure it is one that gives me good stability and speed in my machine, and that it will be useful for a future update of the CPU, among my search I found the G.SKILL TridentZ Series F4-3200C14Q-64GTZSW in a 4x16 kit with a maximum frequency of 3200MHZ and times of 14-14-14-34, my motherboard is an X99-PRO / USB 3.1 and my cpu is an Intel Core i7-5960X Extreme Edition, I have heard that the current bios of this motherboard allow to run 3200Mhz, but my doubt is in the CPU since intel says it supports up to 2133Mhz in memory channels.
my questions are:
1. my configuration of motherboard and CPU if they support the 3200Mhz without problems and with total stability?
2. Has anyone tested this hardware configuration and can you testify its stability?
I said in advance that I want to buy the 3200Mhz kit because in the future I want to upgrade the CPU to one based on Broadwell-E which according to G-Skill if they easily support the 3200Mhz.
*I hope and I can help
https://gskill.com/en/product/f4-3200c14q-64gtzsw
01-23-2018 01:56 AM #2
Menthol PC Specs Motherboard M 10 Apex / XI gene Processor 8700K / 9900K Memory (part number) 2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500 Graphics Card #1 RTX 2080ti / GTX 1060 Sound Card SoundBlaster Ae5 / Onboard Monitor BENQ 32" 4K Storage #1 Intel 900p 480GB/Samsung 960 Pro 1TB Storage #2 Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro CPU Cooler Corsair H150i AIO / H1110i Case Corsair 740 ? Lian Li Air Power Supply Corsair AX 1200i / AX 1200i Keyboard Corsair Mouse ASUS Strix Headset HyperX Cloud Alpha Mouse Pad ASUS Headset/Speakers Logitech Z906 OS 10 X64 Pro Network Router Verizon Fios Accessory #1 Intel Wifi BT pcie card Accessory #2 Red Bull Accessory #3 English Breakfast Tea
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
I have used 4x8 kits of the same timings without any issues, and 2 4x8 kits for 8x8 without issue, the 16GB modules may be a little tougher on the IMC so I cannot say for certain.
Haswell-E is good to 3200MHZ, Broadwell-E to 3400 using 4x8 or 8x8 modules.
I assume you can get them to run at rated speed with some tuning
01-23-2018 12:48 PM #3
- Join Date
- Mar 2017
- Reputation
- 10
- Posts
- 40
01-23-2018 02:52 PM #4
- Join Date
- Jan 2012
- Reputation
- 241
- Posts
- 4,548
You need to make your own decision as what to purchase, I have never tried any kits with 16GB modules myself.
The kits with 16GB modules may be a little more difficult to run at rated speed but I cannot say from personnel experience
I own 2 of the 32GB 4x8 3200mhz kits and did run them together without issue
I would say if you are sure 64GB's is all you'll ever need go with the 8x8 kit, if you think you may someday need 128GB then the 4x16 kit is probably the correct choice
