lukiboss wrote:
So first of all, after system boot i got this message:
I found that asusfancontrolservice but its not running. I cant turn it on and i cant "open file location"
Its normal that its stopped. Its stopped for me aswell. It starts, do its job and stops. At least thats what i think it do, cause it was always shown as "stopped" for me aswell, but it does change fan speed around time of windows login screen after restart according to values i set in the file.
If you cant "go to details" ("przejdź do szczegółów"), you can find the file location by clicking "open services" ("otwórz usługi"), then r.click "AsusFanControlService" there and click "properties". You will find the path to the folder. Go to that folder, and there you will find the FanStore.xml.
I dont know why you are getting this error. Im not getting it. Are you getting it since windows update, or you changed the file and then it started showing? If you changed the file and that was the reason of the error, paste here your FanStore.xml content and lets see what might be the cause.
