Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    ROG Guru: Yellow Belt Array Marko911 PC Specs
    Marko911 PC Specs
    MotherboardAsus Rampage extreme VI
    Processori9 7900x @4,7Ghz cores at from 7x1,20v-3x1,21v
    Memory (part number)G.skill 32GB 3200MHZ CL14 DDR4 quad kit
    Graphics Card #1Aorus 1080ti extreme edition @2032Mhz/12000Mhz
    MonitorAsus something IPS,144Hz ,Freesync
    Storage #1m.2 Samsung EVO 960 1TB
    Storage #2m.2 Samsung EVO 960 500GB
    CPU CoolerEKWB monoblock
    CaseThermaltake view 71 TG
    Power SupplyCorsair RM1000i
    Keyboard rappo wireless keyboard and mouse
    Headset Logitech G933
    OS win 10 pro/64bit
    Accessory #1 HL GTS 360mm/push only
    Accessory #2 HL SR2 360mm push/pull
    Accessory #3 HL SR2 420mm push/pull
    Marko911's Avatar
    Dec 2017
    141
    FanExpert4 issue.Can't control RPM curve.What to do?
    HI,I have a big problem with FanExpert4.I can't control pwm curve on my 3 noctua fans,and they started random ramping up and down.Does anybody have any idea what might be the issue?Fans ,x3 Noctua are connected on HIGH AMP fan header.Before,I couldn't control PWM curve which is set very sharp like 40C at 100%,but it never did that extreme until yesterday.I didn't install any new software or do anything on my PC except watching netflix .
ID:	70868Click image for larger version.
    First pic is NZXT Aer RGB 140mm connected to CPU FAN header,secnod pic is 3x Noctua on HIGH AMP fan header
    ROG Member Array
    Oct 2017
    22
    I see that your fans depend on the VRM temperature. Earlier everything worked well?
    The curve was working properly?
    In my case it never worked properly, my fans are dependent on the VRM temperature and I am forced to use the BIOS.
    Nov 2011
    26
    172
    Hello.
    Are you using the latest Aisuite?
    Did you have another monitoring software active when performing auto fan tuning?
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    141
    Quote Originally Posted by broncogr View Post
    Hello.
    Yes,CAM for NZXT GRid+ but that CAM control ,not mobo.
    And yes,latest AI Suite.(Which started working around two days ago),but I can't set PWM curve,changed source from CPU,VRM and liquid temp to just to CPU,but still..nadaa,can't change that pwm curve..
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    141
    Quote Originally Posted by sevpl View Post
    Not exactly,before I couldn't change pwm curve,but auto fan tuning did semi descent job until AI Suite stopped working,than again it started,but with this kinda of issues.it's too bad one can't manually set pwm curve..
    Nov 2011
    26
    172
    Try running auto fan tuning again without any other monitoring software active
  7. #7
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    141
    Tried that,didn't help at all.Still same ****ty curve,and my ears were falling off.So I disconnected fans from HIGH AMP header and put another Grid controller,finally quiet PC at 750RPM . Now there is only one fan connected to CPU fan header because system wouldn't boot without it.Is it possible manually to override that block?
  8. #8
    ROG Enthusiast Array Quozzo PC Specs
    Quozzo PC Specs
    MotherboardAsus Rampage VI Extreme 0802
    ProcessorCore i9 7900X delidded 4.9GHz @ 1.26v
    Memory (part number)32GB G-Skill Trident Z 3600CL15 @ 1.4v
    Graphics Card #1nVidia 1080Ti FE +175/+750
    Graphics Card #2nVidia 1080Ti FE +150/+500
    MonitorAcer Predator 27" 4K60 IPS G-Sync
    Storage #1Samsung 2TB 960 EVO NVMe
    Storage #2Corsair MX200 1TB && 1TB Toshiba NVMe
    CPU CoolerCustom Water Loop - 2x EKWB 480 XE, 1x EKWB 240 XE
    CaseCorsair Obsidian 900D
    Power SupplyCorsair AX1500i
    Keyboard Logitech G19
    Mouse Razer Naga Epic Chroma
    Headset Sades SA903
    Mouse Pad Yes
    OS Windows 10 FCU
    Network RouterVirgin Superhub 3
    Quozzo's Avatar
    Nov 2017
    73
    Have you tried turning off Extreme Quiet mode? Never saw the point in that anyway when you can control the fans manually. Also, it looks like you have multiple temperature sources controlling the fans which will adjust according to the highest temps from those selected.
  9. #9
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    141
    Quote Originally Posted by Quozzo View Post
    I tried every option on and off.one temps sensor,3x temp sources,nadaa same results.Manually I can set noctuas on high amp ,only min 1100rpm and max 1450rpm.That's horrible.It's way too loud,I don't think fan xpert is even registering accurately rpm ,because on grid+ 1000rpm isn't close to this level of noise.
  10. #10
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,453
    1) To disable the F1 halt message, set CPU fan to "ignore" in the monitoring page of UEFI.
    2) There may be some conflict between the NZXT software/service and Fan Xpert, or the splitter used is sending back more than one tach signal. You can debug both by trying one thing at a time (uninstall other software, try a single fan with no splitter).
    3) If number 2 doesn't check out, you can also try controlling the fans via UEFI, just to see if the issue lies in software.
Tags for this Thread
