Results 1 to 4 of 4
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    G752VS Sonic Studio / Suite not launching. Fresh Win10
    So Sonic Studio won't open. It's running, but the UI won't show up.
    Fresh Win10, I installed RealTek, then SonicStudio after it, (like you're supposed to apparently)
    Anyone know the issue?
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    ROG Guru: Green Belt Array
    Nov 2012
    55
    539
    I'll bite, what laptop is this? First or second replacement? Have you installed all the drivers from your eSupport File? What version Sonic Suite are you attempting to install?
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    I was SOOOOOOO tired, I didn't bother with all that ironically.
    G752VS
    eSupport, installed it all, yes.
    Replacement of Laptop? Third. Don't ask.
    Stock version. It works, sits in tray, just refuses to open. It's soooooo weird. People reporting it in other forums.
    Gosh Blue Lady.. ❤
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    Gawd this thing's so retarded.. it's opening after my reinstall after the Keyboard died.. :f
    Gosh Blue Lady.. ❤
