Results 1 to 7 of 7
    New ROGer Array
    Jan 2016
    5
    AURA DRAM LED Shutdown on sleep
    Is there a way to make RGB DRAM like G. Skill Trident RGB also turn off with the motherboard when you put the computer to sleep? The shutdown feature in AURA seems to only apply to motherboard LEDs. It defeats the purpose of having the lights off if the extremely bright RAM LEDs don't turn off unless I manually do it every time.
    New ROGer Array
    Jan 2016
    5
    oh such a lonely thread
    ROG Guru: Yellow Belt Array
    Jul 2017
    172
    Probably because it has already been answered ;-)
    It is a limitation they said. The modules are still powered on while sleeping.
    Tbh i don't understand why it is so complicated to turn them off before sleep...
    New ROGer Array
    Sep 2013
    1
    Quote Originally Posted by namoi View Post
    I mean I get that the modules are still powered on while sleeping... but Aura has the ability to just turn off the LED on both DRAM and MOBO on the very first page! On the Synchronized tab the ON/OFF switch turns on or off both my MOBO and DRAM LED's... What I don't get is why they haven't included a script that can run when the PC is going to sleep to just set the LED's to turn off. It wouldn't require them to stop giving power to the DRAM, just send the signal that the LED's need to turn off.
    New ROGer Array Vaelore PC Specs
    Vaelore PC Specs
    MotherboardROG Strix B350-F
    ProcessorRyzen 7 1700x
    Memory (part number)GeIL GLB48GB2400C15DC RGB
    Graphics Card #1Asus Dual GTX 1060 3gb
    MonitorVizio M470NV
    Storage #1Western Digital M.2 NVMe 512gb SSD
    Storage #2Seagate 2.5 Hybrid Drive 500gb
    CPU CoolerSwiftech H220 X2 Prestige
    CaseCooler Master Mastercase Pro5 with 4 RGB Thermaltake Riing Cooling Fans - 140 mm
    Power SupplyCorsair CX750M
    Keyboard Logitech K360
    Mouse CoolerMaster Devastator II
    Dec 2017
    2
    same problem
    GeIL Super Luce 3200 should be called "Super Bright while i'm trying to sleep" Ram!! Have to power off to get it to shut down, I hate the hard boot, even though I have a NVMe drive, DAMN THOSE 9 SECONDS TO BOOT!!!
    ROG Guru: White Belt Array Ghozer PC Specs
    Ghozer PC Specs
    MotherboardAsus Prime Z270-A
    Processori7-7700k
    Memory (part number)G.Skill TridentZ RGB DDR4-3200
    Graphics Card #1Asus ROG Strix GTX 1070
    Monitor2x HP 23xi
    Storage #12TB Seagate Firecuda SSHD
    CPU CoolerARCTIC Freezer 33 eSports Edition (Black/White)
    CasePhanteks P400S
    Power SupplyCorsair RM750X
    Keyboard Logitech G510 (Soon to be Asus Claymore)
    Mouse Asus Gladius II
    Headset Logitech Wireless
    Mouse Pad Random Alienware
    Headset/Speakers Creative Inspire GD580
    OS Windows 10
    Network RouterISP Standard (200mbps connection)
    Jun 2017
    82
    Quote Originally Posted by Vaelore View Post
    Use Hibernate instead of Sleep then... LED's will turn off, and wont have to 'boot' (may still do post screen tho)
  7. #7
    Vaelore PC Specs
    MonitorVizio M470NV
    Dec 2017
    2
    Kidding!!
    Quote Originally Posted by Ghozer View Post
    Shutting down is ok for me,The NVMe drive I have gets me back in action in less than 10s.
