Results 1 to 4 of 4
    New ROGer Array
    Jan 2018
    2
    ROG PG279Q Base Replacement
    Hi, I was wondering if their is anyway to get a replacement base/mount for the ROG PG279Q as mine is currently MIA. I see one on Ebay for around the price of a cheap monitor!
    ROG Guru: Yellow Belt Array
    Apr 2016
    218
    Quote Originally Posted by Eastwoodz View Post
    Is it the same as the PG278Q? I have one that's developed horizontal lines and blurry text on the screen. Otherwise it's in perfect condition. It even has a brand new genuine Asus power supply.
    Sent from my ONEPLUS A5010 using Tapatalk
    New ROGer Array
    Jan 2018
    2
    Quote Originally Posted by BoutTime01 View Post
    I'm not entirely sure, I've read the it works with a VESA 100mm mount.
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    121
    1,876
    Both the PG278Q and PG279Q have the 100 X 100mm VESA mount, so the stand is interchangeable. The lighting on the base will still work, the base from the PG278Q doesn't have the glowing ROG logo though.
