Results 1 to 4 of 4
    ROG Guru: Yellow Belt Array Marko911 PC Specs
    Marko911 PC Specs
    MotherboardAsus Rampage extreme VI
    Processori9 7900x @4,7Ghz cores at from 7x1,20v-3x1,21v
    Memory (part number)G.skill 32GB 3200MHZ CL14 DDR4 quad kit
    Graphics Card #1Aorus 1080ti extreme edition @2032Mhz/12000Mhz
    MonitorAsus something IPS,144Hz ,Freesync
    Storage #1m.2 Samsung EVO 960 1TB
    Storage #2m.2 Samsung EVO 960 500GB
    CPU CoolerEKWB monoblock
    CaseThermaltake view 71 TG
    Power SupplyCorsair RM1000i
    Keyboard rappo wireless keyboard and mouse
    Headset Logitech G933
    OS win 10 pro/64bit
    Accessory #1 HL GTS 360mm/push only
    Accessory #2 HL SR2 360mm push/pull
    Accessory #3 HL SR2 420mm push/pull
    Marko911's Avatar
    Dec 2017
    140
    PCH temps-Is it normal to be hovering around 70C in Idle?
    Hi,hope this is my last problem post .I noticed my PCH temp are around 67-70 in idle.Is that normal to PCH be the hottest part of my system?What are your PCH temps?
    Nothing is OCed,except RAM XMP at 3000Mhz.(around 40C),CPU idle(25-35C),GPU idle(25-28C)
    9 fans are pushing air in and one at the back is exhaust fan.Thanks in advance for your advice.two rads top420mm-push/front360mm -push/pull,both 60mm thick,D5 pump,Thermaltake View 71 TG case,corsair RMi1000i.
    ROG Member Array
    May 2015
    9
    Do you mean like this
    I have not been able to correct it either .. Been running for two years and never been able to bring that temp down.
    Tried to upload png image , but no success.. Mine shows running at 71 C.
    ROG Guru: Orange Belt Array mpoffo PC Specs
    mpoffo PC Specs
    MotherboardRampage VI Extreme
    ProcessorIntel 7900x
    Memory (part number)G.Skill F4-3200C16Q-32GTZR = 32 GB 3200 Kit
    Graphics Card #1Nvidia Geforce 1080 FE
    Graphics Card #2Nvidia Geforce 1080 FE
    Sound CardSound Blaster Z
    MonitorNvidia Surround (5960 x 1080)
    Storage #1Samsung 840 Pro256 GB/850 Evo 500 GB
    Storage #2WD 2 TB & 4TB Black Hard Drives
    CPU CoolerCorsair H115i
    CaseCorsair 900D
    Power SupplyCorsair 1200i
    Keyboard Corsair K95 - RGB
    Mouse Corsair Glaive
    Headset Turtle Beach Surround
    Mouse Pad Corsair MM800 RGB Polaris
    Headset/Speakers Logitech 5.1 Surround THX Speakers
    OS Windows 10 Pro - 64 Bit
    Network RouterNetgear Nighthawk x10 R9000 w/ Plex
    Accessory #1 Corsair Comm. w/ Corsair HD Fans - NZXT Hue +
    Accessory #2 DX Racer King Series Chair
    Accessory #3 3D Printer/HTC VIVE
    mpoffo's Avatar
    Jan 2013
    17
    254
    Quote Originally Posted by Marko911 View Post
    Asked and answered earlier. Per Raja this is completely normal.
    https://rog.asus.com/forum/showthread.php?99323-Rampage-VI-Extreme-PCH-temps-What-is-safe
    RVIE X299 System:
    Windows 10 Prof 64-bit | Intel Core i9 7900x | ASUS Rampage VI Extreme | Corsair AX 1200i PSU
    Corsair 900D | 32 GB 3200 G.SKILL Trident RGB Series | EVGA GTX 1080 in SLI (x2) | Nvidia 2D Surround Set-up
    Samsung 840 PRO 256 GB | Samsung 850 EVO 500 GB | Intel 520 SATA SSD 240GB HD | 2 & 4 TB WD Black Hard Drive
    Creative Sound Blaster Z | Logitech THX 5.1 speaker setup
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    140
    Great,if it's in the specs range than ok.I didn't know that. When I googled the problem,all post were like for older chipsets so I had to ask here.Oddly,I didn't see that earlier post for RVIE PCH.
Tags for this Thread
