Results 1 to 10 of 10
Thread: 18 Months
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    18 Months
    Just for interest...
    After 18 months use....
    Not terrible...not great.
    Nickel plating is pretty damaged on cold plate (copper) but 100% on top of block (brass)...bare spots on coldplate were greenish (oxide) before clean up.
    Jet plate perfect...stainless steel so no surprise there.
    All copper in loop...distilled water changed every 3 months more or less.
    Performance was great throughout time in loop.
    Have a copper acetal block on there now...will open that soon enough...
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,377
    What did you use to clean the oxide?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    I've an all copper Supremacy here that was used for 3 years that looks in much better condition than that. It's all in the mix.
    Apr 2012
    481
    13,400
    Quote Originally Posted by xeromist View Post
    salt and vinegar
    EDIT: hang on...do you mean the light polish I gave it with a disk cutter
    Quote Originally Posted by Silent Scone View Post
    There is no mix...just bad plating...you can see where the jet plate was the nickel has been mechanically stripped off... etc.
    Top is well plated...
    Apr 2012
    481
    13,400
    Maybe a couple of months less use...but pretty much same 18 months
    Looks good to me...looks all together a better grade of copper?
    I'd recommend Cu only block from now on then...no plating
    ROG Junior Member Array
    Jul 2018
    3
    what do you use in the loop besides distilled water?
  7. #7
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    @jhoffberger - if anything was added/mixed then it's no longer distilled water, lol.
    Looks like a sort of galvanic fretting to me. Dissimilar metal ions in solution (dissolved copper-nickel plating) which become more reactive and more acidic (and changes the pH of the coolant itself) when exposed to the block's "hot" sites.
    On PC cooling, I use a very weak ethylene glycol mix with lots distilled water and a little bit of Chemtex Nalcool 2000 or No-Rosion or Bar's Leaks Anti-Rust 1311 - these additives are all corrosion-inhibiting chemical buffers which neutralize those aqueous metal ions and those gassed-out broken polymer fragments, the last one also contains a lubricant (for the pump and any other moving parts) but I've never seen this lube make any real difference.
    https://www.knowyourparts.com/techni...l-and-protect/
    http://www.dtic.mil/dtic/tr/fulltext/u2/466284.pdf
    [/Korth]
  8. #8
    Apr 2012
    481
    13,400
    Quote Originally Posted by jhoffberger View Post
    Nowt....pure distilled water and change it every 2-3 months...
    I have a raystorm neo coper only block at the moment and it looks perfect too.
    Problem was simply the bad EK plating...they have gone from a watercooling company to a fashion accessory company IMO
  9. #9
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    @Arne
    You can use a TDS meter (or even a high-precision DMM) to determine if your pure distilled water is in fact still pure water after being immersed in the loop for a while. It's obviously contains corrosive ions if it's corroding your plates ... and a corrosion inhibitor additive will slow that down greatly. Poor-quality plating on one piece might be part of the mechanism, but contaminated water full of reactive ions is the other part of the mechanism. Probably not a problem most of the time, but it's never nice to find nasty surprises like that inside your blocks when you inspect them.
    [/Korth]
  10. #10
    Apr 2012
    481
    13,400
    Quote Originally Posted by Korth View Post
    I get a dropper and drip 2-3 drops in my eye every now and then...if I don't lose my cornea I call it good to go...
    I had a supreme HF from the old EK that was plated and came away from the same loop pristine...as well as two HWBot edition plated GPU blocks that did the same...old skool EK seemed fine....I've had nothing but bother with plated Supremacy and Supremacy EVO blocks (not to mention screw problems on their coldplate after they decided to cut costs recessing) so I really don't think it's acid running in my loop...the copper doesn't even look the same to me between the all copper and the plated...
    Current XSPC block is high quality and it's pristine...6 months so far
