Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
  1. #21
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    120
    1,712
    Quote Originally Posted by MLGbr View Post
    I found the final solution for the Rog Spatha Mouse.
    After
    1) Updating Rog Armory
    2) Remove Rog Armory from Windows start
    I CHANGE THE USB PORT !!!
    Windows detected the mouse, did the installation, and now it works perfectly.
    Never again of problem of bad detection.
    100% solved!!!
    Which USB port was giving you issues? Front-panel?
    DId you update to Armoury 2.04.09?
  2. #22
    New ROGer Array
    Jan 2018
    15
    Cool Answers
    I'm still with Armory 2.04.07 (I have not updated it since).
    Windows had already registered the mouse on that USB port, so it was necessary to change the USB port so WIndows installed the mouse "from scratch" on the computer.
    It's a Windows 7 trick.
    When a USB device is not properly installed in a USB port (and errors or failures occur), switching the USB port will force Windows to install the hardware "from scratch" on the other port, and the problem disappears.
    I use two mouses.
    Rog Spatha in the USB 2 front
    Another vulgar mouse in rear USB ( was used, when Spatha presented problems )
    Thus, complete solution went through 3 steps:
    1) Upgrade Rog Armory ( resuscitate the mouse. Before that, it did not even work on another computer. )
    2) Remove Rog Armory 2.04.07 from start (fixes the problem of stopping detecting the mouse every 5 minutes)
    3) Replace the USB port installation (solve all random detection problems)
    Now both mouse are working, in rear USBs ports.
  3. #23
    Aug 2014
    120
    1,712
    Occasionally the front panel ports and hubs can cause problems, best to go with rear ports when troubleshooting.
    Try 2.04.09 if you run into any more issues.
  4. #24
    ROG Member Array paul roperos PC Specs
    MotherboardROG Maximus VIII Hero Alpha
    ProcessorIntel 6700K
    Memory (part number)16GB Corsair Vengeance LED red
    Graphics Card #1ROG Strix GTX 1070 OC
    Monitor32inch Sony Bravia TV
    Storage #1Samsung 850 EVO 250GB
    Storage #2WD Blue 1TB
    CPU CoolerCorsair H100i V2
    CaseNZXT S340 Elite
    Power SupplyCorsair RM750i
    Keyboard ROG Claymore & ROG Strix Flare
    Mouse ROG Spatha & ROG Gladius
    Headset ROG Centurion & ROG Strix Wireless
    Mouse Pad ROG Sheath & ROG Scabbard
    Headset/Speakers Logitech Z623
    OS Windows 10 Home
    Network RouterDLink
    Accessory #1 Asus External DVD Drice
    Accessory #2 ROG Spothlight
    Dec 2016
    6
    can I post a review here?
    CONS
    -expensive
    -not ergonomic
    -too heavy to be a mouse
    -crappy scroll wheel
    -none stable connectivity (even at 1.5 meter)
    -none replaceable battery
    -only lazer censor
    -not supported by AURA sink
    -buggy software
    -easy to be lowbat
    -no ASUS Support if you have a problem
    Pros
    -design (looks cool on the desk)
    -2 cables include
    -2 sticker badge included
    Overall a expensive and crappy mouse HAHAHA (dont buy this mouse)
Tags for this Thread
