Annoying issue with my fans
soar-x
Hi all,
Recently I decided to redo my cable management. When all was said and done I turned on my computer and noticed my fans were going a bit faster than normal. I have 6 Corsair 120HD RGB fans installed. I went into BIOS to try to solve this but it did pretty much nothing. The silent mode for the fans didn't change anything.
I decided to use AI Suite (I really dislike using softwares to tune my PC settings) and the silent mode was definitely a lot better for my fans. However, they don't detect my extension fans so I can't adjust them. They worked before but now it says it can't identify them.
If anyone could help me out that'd be great because I can't adjust my extension fans to the setting I'd want them at. Also, if possible if someone could suggest something in BIOS so that I don't have to use a software to tune the fans I'd appreciate it. Because as far as I know, your fan settings will only go into play once you log in and your AI Suite starts up.
Heini
Level 11
It would help to know which MB you are using.
