01-29-2018 12:05 PM - last edited 3 weeks ago by ROGBot
01-29-2018 12:29 PM
01-29-2018 12:43 PM
01-29-2018 01:12 PM
01-29-2018 01:28 PM
01-29-2018 01:51 PM
02-02-2018 06:40 PM
Brighttail wrote:
I've been using Mayhem's pastel (Red, Blue and Purple) over the last 6 years or so and have never had an issue with gunk build up. I ran a Swiftech CPU block, some Asus 980 Poseidon and MSI Sea Hawks with the EK waterblock and NEVER an issue with gunk. I really think it was these new Xflow radiators. I probably didn't run blitz long enough or didn't flush them in the sink enough, tho I boiled Distilled water and let it set a minute or two so I'd be pouring almost boiling water in to them before sloshing them around. I had a lot of crap come out of them at the beginning but eventually it came clean, so I really think it was the rads in the end that had even more **** in them.
Yeah the monoblock is live n learn. Some water dripped onto the motherboard behind the shield, but I was using a PSU by-pass so no electricity to the board. It will be a few days before I get my monoblock it looks like so it will have some time to dry. Thankfully I was on my fourth flush so no red pastel left in the loop really and almost 100% distilled water.
02-03-2018 01:18 AM
02-03-2018 03:05 AM
02-03-2018 07:50 AM
Marko911 wrote:
Jesus,don't put cola in copper rads!That green color that came is part of Cu oxidation caused by phosphates in cola!
Rinse your rads with distiled water once or twice and that's enough. I personally like HL water-soluble flux so I don't have to flush my rads.
If you want to flush clean your rads and blocks from previous color dyes than just use a freaking active charcoal with heated water around 50C.It's safe,it doesn't destroy or interact with metals.and it's cheap.
In my opinion EKWB color additives are safe,don't cause any gunk to build up and their pigment is fairly easy to remove even with just plain water.
You will not notice any difference in using demineralized water,distilled double-triple,sterile water.Difference in these beforementioned waters is so insignificant in use on nickel-ed plated metals,and there will be no significant changes in your loop block metals like cu,brass or their plating's.
