Results 1 to 6 of 6
    ROG Member Array
    Jan 2018
    5
    Unhappy Help with re-arm pc
    specs:
    CPU: I7- 3820.-
    VGA: AMD Radeon HD 7970
    RAM: 8Gb x 4 (ddr3 - 1600) G. Skills
    SSD: 500gb Crucial m4
    HDD: 500gb
    Motherboard: Asus Rampage IV (DEAD!!!!!) ;(
    Cooler: Thermaltake frio extreme
    power supply: Corsair TX850W
    - My motherboard died because some pins where the cpu goes broke.
    EDIT:
    In the end I decided to buy new parts for my pc, now I am between trying to use my ram or change to a ddr4.
    - So, what is the most current socket that supports the ram ddr3? or it is not convenient to continue using my ram?
    - With regard to the cooler, can I continue using it right?
    - Regarding the amount of money I have, it is difficult because I have to buy materials for my university career, dentistry (around 1800 USD), in the end I would have between 350 USD to 670 USD, and that I can probably buy the parts for my pc in 1 month (at the beginning of March)
    -Pd: the pc is just for playing, like Lol, PUBG, Fortnite, Rocket League, Cs: Go, Black Desert.
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,254
    Upgrade is the best option. It'll be pretty hard to find a new motherboard that supports your CPU. Even if you did, it would be a used one probably.
    ROG Member Array
    Jan 2018
    5
    Quote Originally Posted by Chino View Post
    if it is not too much trouble, which generation is the best to upgrade my pc and that is not so expensive.
    - Actually I do not know much about which is better than another, but if you could give me the models of the cpu - MoBo - Ram, to ultimately put together a little more money.
    ROG Enthusiast Array offthewall69 PC Specs
    Laptop (Model)Alienware 15R3 (for eh, work)
    MotherboardMaximus IX Hero
    ProcessorI7 7700K underwater
    Memory (part number)G.SKILL DDR4 3200, F4-3200C16Q-32GTZR
    Graphics Card #1EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    Graphics Card #2EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    MonitorAOC Agon AG352UCG 35” Curved G-Sync
    Storage #1SAMSUNG 850 EVO 2.5" 1TB SSD
    Storage #2SAMSUNG 850 EVO 2.5" 500GB SSD
    CPU CoolerCPU & GPU in an open loop with EKWB blocks and pump and alphacool 120 and 360 x-flow radiators
    CaseIn Win 305 Black
    Power SupplyEVGA SuperNOVA 1000 G3
    Keyboard Razer Blackwidow
    Mouse Razer DeathAdder
    Headset HyperX Cloud II Gaming Headset
    OS Windows 10 Pro
    Accessory #1 Razer Tartarus Keypad
    Accessory #2 EK-FB ASUS M9H Monoblock - Nickel
    offthewall69's Avatar
    Apr 2015
    35
    Did the socket pins break or get bent? While you're waiting for the funds to upgrade, bent (and sometimes even broken) pins can be repaired. Many videos on line that show the process; basically the tools you need is a strong light, good magnification, thin push-pin and sometimes a razor blade to re-align. It's tedious work, but if you're careful you could resurrect the board. If you go the upgrade route, you'll probably have to replace your cpu and ram in addition to the motherboard. Expect a hefty budget...
    ROG Member Array
    Jan 2018
    5
    Quote Originally Posted by offthewall69 View Post
    I hope the pines are bent, buy some things to try to repair them, but while these arrive, I am looking for some other option.
    OS Windows 10 Pro
    Apr 2015
    35
    Hope all is going better for you Manolete. Been on the road lately so I wasn't monitoring your progress.
    While there are some LGA1151 boards that support DDR3, they will limit the capabilities of a newer CPU.
    Based on your budget, and the possibility of being able to repair the board, I'd recommend an X79 replacement board until you can either:
    - Fix the board you have, or
    - Upgrade your entire system
    With that in mind, I'd recommend an inexpensive new board like this to tide you over (about $100USD) until you can effect the repair or replacement. Best of luck on finding a solution.
