Results 1 to 3 of 3
    ROG Member Array Nudoxsys PC Specs
    Nudoxsys PC Specs
    Laptop (Model)G752VL
    MotherboardASUS STRIX Z270E GAMING
    ProcessorIntel 7th Gen Core i5
    Memory (part number)16GB G.SKILL TridentZ RGB
    Graphics Card #1ASUS STRIX GTX 1080 Ti
    Monitor29" 1080p LF Ultrawide Monitor
    Storage #1Hitatchi 3TB HDD
    CPU CoolerDEEPCOOL Gamerstorm Captian 360 EX White RGB
    CaseThermaltake View 31
    Power SupplyCORSAIR RM850x
    Keyboard CORSAIR K95 Platinum
    Mouse ROG Spatha
    Headset DNA by Monster headphones
    Mouse Pad CORSAIR Polaris
    Headset/Speakers Razer Leviathan
    OS Windows 10 Home
    Dec 2017
    7
    Addressable RGB headers?
    I have a Strix z270E Motherboard and I noticed that it has two 12V RGB headers on it, but I wanted to attach some Aura Sync Addressable RGB strips in my computer. I know if I were to upgrade to the z370E series MB, it has one Addressable header on it that I'd be able to use, but earlier today I came across a little piece of hardware that adds additional RGB headers to your motherboard (Whether your Motherboard has any preinstalled or not). I wanted to know if anyone knows of a product that adds some Addressable RGB headers?
    While I don't mind upgrading to the Coffee Lake Core series, I think I'd rather stick with my Kaby Lake for right now lol
    Also I'm not sure if I can post links here, but if I can, I can provide a link to the product I mentioned earlier.
    ROG Guru: White Belt Array Ghozer PC Specs
    Ghozer PC Specs
    MotherboardAsus Prime Z270-A
    Processori7-7700k
    Memory (part number)16GB G.Skill TridentZ RGB DDR4-3200
    Graphics Card #1Asus ROG Strix GTX 1070
    Monitor2x HP 23xi
    Storage #1Samsung 970 Pro 512GB
    Storage #22TB Seagate Firecuda SSHD
    CPU CoolerAntec 120mm AIO
    CasePhanteks P400S
    Power SupplyCorsair RM750X
    Keyboard Asus ROG Strix Flare
    Mouse Asus ROG Gladius II
    Headset Steel Series Arctis 5 RGB
    Mouse Pad Random Alienware
    Headset/Speakers Creative Inspire GD580
    OS Windows 10
    Network RouterISP Standard (350mb/35mb)
    Jun 2017
    93
    Quote Originally Posted by Nudoxsys View Post
    The Z270 are not Addressable, look at the pin out, if it's Ground/RGB then it's none addressable, if it's +/-/Data(return) then it's addressable.. (there are 3 and 4 pin addressable configurations, but only 4 pin none addressable)
    What's this device you have found? if it's the Akasa Vegas Control Card, then that's none addressable, as is the control panel...
    Nudoxsys PC Specs
    Mouse ROG Spatha
    OS Windows 10 Home
    Dec 2017
    7
    EZDIY TAURUS PCIE Slot
    https://www.amazon.com/gp/product/B0...A2A4XZZKQVDB4S
    And yes, I know mine doesn't have any addressable headers (Sadly), but I noticed this product could add regular headers (like mine) to a motherboard that doesn't have any headers whatsoever, or add additional headers to ones that do.
    I was curious if there was a product similar that could add Addressable headers even though my MOBO doesn't have any, although I doubt it.
Tags for this Thread
