Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Enthusiast Array
    Dec 2017
    29
    First custom loop.
    Motherboard: Asus Maximus Formula X
    CPU: Intel i7 8700k
    GPU: Asus 1080ti O11G OC
    Ram: Gskill rgb trident Z 16gb 3000Mhz
    Case: Corsair Crystal 570x case with 6 HD 120 rgb fans connected with the commander pro
    Psu: Corsair AX760
    Blocks, fittings, pump, radiators, tubes, all Watercooled by Ekwb.
    Cable mod custom extentions.
    Screwed up a few bends, will redo them when I do maintenance.
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Nice looking, well done!
    I am also partial to Corsair cases.
    Davemon50
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,682
    Nice!
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    148
    1,971
    Great first effort, better than most peoples 3rd or 4th!
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,454
    Nice first attempt. As said by others, this is a lot better than most of the builds more experienced people post pictures of.
    Dec 2017
    29
    I have a question, Im still getting bubbles in 1 part, but I don't see a leak. Every time I start my computer a few decent size bubbles appear inside the tube where the inlet on the cpu block is, and just gets stuck there. I go into bios, ramp up my pump speed to push it through and it travels to the resevior and floats to the top, out of the loop. (ive done this 5 times or so to try to get rid of it)
    The only thing I can think of is that the rotary 45 degree fitting isn't properly sealed, or there's something wrong with the formula x ek crosschill block. What are the chances that air is getting into the loop, but water isn't getting out?
    I built this around 3 weeks ago, I would've thought the bubbles would have worked its way out by now.
  7. #7
    Apr 2012
    505
    13,682
    Have you tried tilting the case gently forward to 45 degrees...might be some air trapped in that top rad? Or forward and backwards...slowly...often air trapped in a new loop...
    Do you have an anti-cyclone insert in res? any chance it sucks down air at any point?
    I've never used a rotary fitting...don't trust that kind of thing myself...not sure if it could let in air as pump applies pressure to loop if the loop is totally closed...you listened closely?
  8. #8
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Where is the high point in this system? It appears to be the top of the radiator from the pic you posted. If it is then it is possible you are circulating through the trapped air at the top of the radiator every time you pump it. It has to vent, is there a vent at the top of the system? Where's the fill point? Sometimes a schematic helps to diagnose problem points.
    Sometimes air gets trapped in a water loop at the high point and can be very difficult to get out. So you could have some stubborn bubbles that are still working their way out of the system even after 3 weeks. A system separator sometimes helps with that, but has some pressure drop to it so you have to run your pump a little faster (translated: louder) to accommodate the same heat transfer rate.
    As you suggested you may also have a fitting that is not quite firm enough, and when the system cools down it sucks a non-visible amount of air into the system. You might have to snug them up a bit.
    Davemon50
  9. #9
    Dec 2017
    29
    Quote Originally Posted by davemon50 View Post
    You are correct about my top radiator being the top most part of the loop. There is no vent there, only fill port is the top of my resevior. I've assumed it would be air in the top radiator, however when I start the system I pay very close attention where the bubble first appears. And I've never seen it come through the tube from the radiator to the inlet of the formula integrated block. The first place I see it appear is the nearly 180 degree tube coming from the outlet of the formula vrm block into the inlet of cpu block.
    That's why I'm worried that the formula block isn't sealed properly, or there's a micro leak in the rotary fitting on the outlet if the vrm block. I've tried tightening those nearby fittings twice and they don't budge.
    I can't imagine that much air getting caught in the vrm block on the Asus Formula based on what I can see the innards look like online, but maybe I wrong.
    I wouldn't be as worried if I saw bubbles coming from the radiator through that outlet tube, but like I said I haven't seen a single one when I start the system in that area. It's always visible first in the nearly 180 degree tube after the vrm block.
  10. #10
    ROG Member Array stainlineho PC Specs
    MotherboardMaximus X Hero WiFi-AC
    Mar 2018
    22
    Run the computer on it's side for 24 hours.
