Results 1 to 6 of 6
    New ROGer Array
    Feb 2018
    6
    G74SX replacement Power Ribbon?
    Anyone know where I can score a sumitomo-g awm 2896 80c vw-1 10 pin ribbon cable? Everyone I ask says "Need the serial number of the laptop" but the sticker wore away and my client has no idea what it was. The current one is crimped horribly and is suspect of the power button only lighting up for 3 seconds and then going out. Motherboard has already been swapped out and not even bothering with the battery, just using the power cord.
    I believe its 10 pin as I count ten contacts at the clip.
    Can anyone direct me to reliable parts or send me a parts list because the lack of Serial Number is stonewalling all attempts to fix this device.
    Sean M.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,129
    have you tried ebay?
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Guru: Orange Belt Array
    May 2011
    28
    390
    Quote Originally Posted by Sean.M View Post
    Sean M.
    Your client should have registered their device, then they would have it.
    Here's the Serial number to my old G74Sx. Not sure why the serial number would be needed if you know the model #.
    Serial Number: B9N0AS790830396
    I have long since sold the laptop so the info is of no real importance to me. That ribbon cable in a search engine does pull up multiple ebay listings. That may be the easiest place to get one since that laptop hasn't been in production for sometime. My purchase date says 3/1/2012, so almost 7 year old device. Good luck!
    ALIENWARE R17 R5 - i7 8750H - GTX 1070 @ 1.9Ghz - 16GB DDR4 - NVMe 970 EVO 1TB - SSD 960 EVO 1TB
    SOLD: ASUS G703VI-XH74K
    RETIRED: ASUS G752VY-DH72
    RETIRED: ASUS G750JH DB71
    RETIRED:ASUS G74Sx DH72
    New ROGer Array
    Feb 2018
    6
    Thanks!
    Quote Originally Posted by MrRuckus View Post
    Right? I submitted the part number of the motherboard which would make more sense but that doesn't seem to cut it. Thanks, I'll try the S/N and I've been looking at eBay, but I'm trying to get the same swanky type that has the reinforced ends like the original.
    Thanks again for all the replies!
    New ROGer Array
    Feb 2018
    6
    Score one for the independent technician!
    Thank you again, everyone, for the advice. I managed to score the part from IMPACT COMPUTERS in Florida, see link below. The device is up and running and I am in BIOS. Note to other DIY fans:
    Either it is the current generation of MoBo's or a quirk in certain models, this device will not POST without RAM.
    Now I will start a new thread about RAID!
    Thanks again! And for anyone who wants a new (or relatively new) powercable, here's the link:
    https://www.impactcomputers.com/14g1...4_10846_110218
    New ROGer Array
    Feb 2018
    6
    Oops! Forgot to list the part number!
    For anyone who needs to order it, the part number is: 14G124150103
    and the descriptor is: 14G124150103 - Power FFC 10P, 0.5mm, L:150 For G74SX Notebook
    Thanks again!
Tags for this Thread
