ROG Rapture GT-AC5300 - Firmware 3.0.0.4.384.20308 with AiMesh and KRACK Fix
MasterC
Community Admin
Community Admin
The latest firmware for the ROG Rapture GT-AC5300 is available for download. If you encounter any issues, please report here in this thread. Thanks!
Ver. 3.0.0.4.384.20308
http://dlcdnet.asus.com/pub/ASUS/wireless/GT-AC5300/FW_GT_AC5300_300438420308.ZIP?_ga=2.220645659.20...
Try out AiMesh if you have two or more of the following routers:
AC1900
RT-AC68RW
RT-AC68UF
RT-AC68R
RT-AC68W
RT-AC1900
RT-AC1900U
RT-AC68U_White
RT-AC68P
RT-AC1900P
RT-AC68U V2
RT-AC68U
AC2900
RT-AC86U
RT-AC2900
AC3100
RT-AC88U
RT-AC3100
AC5300
RT-AC5300
Info regarding AiMesh:
https://www.asus.com/AiMesh/
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
11 REPLIES 11
stefan063
Still having issues with USB HDD or stick (no matter the slot No.) Memory stuck at 99% and router becomes slow and unresponsive.
I also have this issue, i read previous post stating this is normal functionality but i just cant image the ram being pegged as the normal with USB media is connected. i will say i dont suffer from performance issues when its pegged but then again i may need more time to test.
To who I can send syslog? I have miles and miles of ERRORS.
There’s something wrong with VPN Fusion!!!
Every time you go to use either Open VPN or L2TP, the VPN cuts the internet out....
The other issue is once you’ve turned on the VPN, you can’t navigate back to the VPN Fusion tab as it takes forever for you to try to connect...
I understand that VPN Fusion is still fairly new and is only 6 months old but seriously needs to be fixed of bugs!! The new Netgear Duma OS XR500 is introducing VPN Hybrid so I will be comparing it to this!!!!
Confirming the following tested with NordVPN using OpenVPN protocol:
09-06-2017 - 3.0.0.4.382.12184 - OpenVPN Works - No VPN Fusion
25-08-2017 - 3.0.0.4.382.15984 - VPN Fusion - OpenVPN Broken
26-01-2018 - 3.0.0.4.384.20287 - VPN Fusion - OpenVPN Broken
01-02-2018 - 3.0.0.4.384.20308 - VPN Fusion - OpenVPN Broken
Omg I’m blind.
Turns out I didn’t configure the type from internet to the actual VPN... lol*
Let's encrypt auth issue after factory reset (initialize) ...
Hi guys,
I have a question for you.
I see this router have many issues with OverVPN but works with PPTP or L2TP ???
I want a buy one but I'm looking for compatibility for PPTP or L2TP.
Thanks very much !!!
Kind regards.
