Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    New ROGer Array
    Feb 2016
    9
    Wanting RGB Case Fans for Aura
    As the title says, I am looking for RGB case fans that are Aura compatible. I have looked all over google and a few tech forums and a lot point me in the direction of the Aura Sync Compatibility page but I do not see fans on there, everything else but. I know about the Phanteks Halos and Halos Lux, which is what i might have to lean towards, but I would like to just get a fan that is already to be hooked up and synced. Another thing I am looking for is the halo effect like the Thermaltake riing fans but can not find any that are compatible so I thought I would come to the place that is supposed to know everything about ASUS and Aura. Oh by the way, I have a Crosshair VI Hero motherboard that I am about to do an RGB build with so you see why I am looking for these fans. Any suggestions or fingers pointing in a direction for me would be grateful. Thanks.
    New ROGer Array
    Feb 2016
    9
    so I take this as no one knows or just does not want to answer
    New ROGer Array
    Feb 2016
    9
    I really can't believe that none of you all is willing to answer this question, even after I have come to a forum that is supposed to know about the specific question that should be answered here more than any other place. Even after 80+ views.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,357
    New ROGer Array
    Feb 2016
    9
    First off, Thank you for answering Nate152. It has been hard trying to find what I am looking for and people seem to not want to answer the question directly. Instead they tell me why I should or should not do it. I have looked at all of these fans but unfortunately they are not what I am really looking for. I am looking for something in that looks like the Thermaltake Riing fans or the Phanteks Halos/lux. The bad thing about those is that Thermaltake fans are not Aura compatible and Phanteks does not do 200mm which is what I am looking for, 200mm that is. Although I saw on a different forum that the Thermaltake Taiwan site sells a Thermaltake riing fan that is compatible but I could not read the site itself since it was in a different language. But all other sites does not have that product if it exists. So again if you know of ones that look the same but comes in the size I am wanted, please let me know. Or if you don't, please let me know. Again thanks for answering.
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,357
    The Coolermaster Masterfan comes in 200mm and supports aura sync.
    http://www.coolermaster.com/cooling/...an-mf200r-rgb/
    The Bitfenix Spectre Pro comes in 200mm and supports aura sync.
    https://www.amazon.com/BitFenix-Spec.../dp/B077Q8B5GV
  7. #7
    New ROGer Array
    Feb 2016
    9
    Quote Originally Posted by Nate152 View Post
    I do know that but it is not the look I am going for. I do not want the full fan look of RGB. Just the Halo or ring look like Thermaltake Riing RGB fans. But again, non are 200mm.
  8. #8
    New ROGer Array stuartl89 PC Specs
    stuartl89 PC Specs
    MotherboardASUS ROG Maximus X Code
    ProcessorIntel 8700K
    Memory (part number)CMR32GX4M4C3600C18
    Graphics Card #1ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
    Sound CardCreative Soundb Baster ZX
    MonitorAcer Predator X34 Pbmiphzx
    Storage #1Samsung 960 EVO Series - 500GB NVMe
    Storage #2Samsung 850 EVO 1TB 2.5-Inch SATA III
    CaseThermaltake Core P7
    Power SupplyCorsair HX1000i
    Keyboard Corsair K70 Rapidfire
    Mouse Logitech G502 Proteus Spectrum
    Headset/Speakers Logitech Z906
    OS Windows 10 home
    Jun 2012
    8
    I think you can use the tt riing fans with their tt sync controller premium and connect it to an aura sync motherboard. At least I hope it works. I have it in the build I’m working on but am still doing the hardline so I haven’t fired it up yet to check.
    -S*
  9. #9
    ROG Enthusiast Array offthewall69 PC Specs
    Laptop (Model)Alienware 15R3 (for eh, work)
    MotherboardMaximus IX Hero
    ProcessorI7 7700K underwater
    Memory (part number)G.SKILL DDR4 3200, F4-3200C16Q-32GTZR
    Graphics Card #1EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    Graphics Card #2EVGA GTX 1080 FTW Hydro Copper 08G-P4-6299-KR underwater
    MonitorAOC Agon AG352UCG 35” Curved G-Sync
    Storage #1SAMSUNG 850 EVO 2.5" 1TB SSD
    Storage #2SAMSUNG 850 EVO 2.5" 500GB SSD
    CPU CoolerCPU & GPU in an open loop with EKWB blocks and pump and alphacool 120 and 360 x-flow radiators
    CaseIn Win 305 Black
    Power SupplyEVGA SuperNOVA 1000 G3
    Keyboard Razer Blackwidow
    Mouse Razer DeathAdder
    Headset HyperX Cloud II Gaming Headset
    OS Windows 10 Pro
    Accessory #1 Razer Tartarus Keypad
    Accessory #2 EK-FB ASUS M9H Monoblock - Nickel
    offthewall69's Avatar
    Apr 2015
    35
    Quote Originally Posted by Omikse View Post
    I haven't seen a 200mm halo rgb fan yet; sorry. You might be stuck with the full look for now.
  10. #10
    ROG Member Array Velcade PC Specs
    Velcade PC Specs
    MotherboardROG MAXIMUS X HERO (WI-FI AC) ATX LGA1151 Motherboard
    ProcessorIntel - Core i7-8700K 5.0GHz 6-Core Processor
    Memory (part number)G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Memory
    Graphics Card #1GeForce GTX 1080 STRIX-GTX1080-A8G-GAMING
    MonitorPG279Q ROG Swift
    Storage #1Crucial - MX500 2TB 2.5" Solid State Drive
    Storage #2Western Digital - Gold 4TB 3.5" 7200RPM Internal Hard Drive
    CPU CoolerFractal Design - Celsius S36 87.6 CFM Liquid CPU Cooler
    CaseFractal Design - Define R6 Gunmetal TG ATX Mid Tower Case
    Power SupplyEVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply
    Headset Sennheiser HD650
    OS Microsoft - Windows 10 Home OEM 64-bit
    Network RouterRT-N66U
    Accessory #1 Blue Yeti Microphone
    Velcade's Avatar
    Jan 2018
    16
    Lightbulb ASUS knows...
    Believe it or not ASUS has a pretty good handle on what's compatible with their stuff.
    https://www.asus.com/campaign/aura/u...romotions.html
    Here is everything currently compatible with Aura Sync
    For your situation: Cooling > Cooler Category > Case Fan
