asus turbo gear g752vs "extreme" mode activated at boot up ... change to 'standard' ?
maungers
Hello!
I have a laptop g752vs
In the asus turbo gear at boot up windows, the "extreme" mode is activated ... can I put the default mode "standart"
Thanks
hadarych
maungers wrote:
Hello!
Thanks
nope
Hi maungers,
I have the same issue. My system used to always start up in the Standard setting however since disconnecting the adapters and leads etc (as it's mainly used at a desk all day) it has more often than not; started starting up intermittently in the Extreme setting. Obviously not good; as it's causing unnecessary wear on the machine when it really doesn't need to be in the extreme setting.
