Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Guru: White Belt Array orcinus PC Specs
    orcinus PC Specs
    MotherboardRampage V Extreme 3504
    Processori7-5960X @ 4.585GHz strap 125, BCLK 131
    Memory (part number)F4-2800C16Q-32GRR@13-13-13-33-CR1-BCLK 131,
    Graphics Card #1TITAN Xp
    Graphics Card #2TITAN Xp
    Sound CardAsus Xonar Essence STX
    MonitorDell UP2715K
    Storage #1SM 960 Pro 2TB RADI1
    Storage #2SM 960 Pro 2TB RAID1
    CPU CoolerEKWB custom 2x480mm + 1x560mm
    CaseCaseLabs Magnum STH10
    Power SupplyCorsair AX1500i
    Keyboard Logitech G710+
    Mouse Logitech G900
    Headset Sennheiser PXC550
    OS Windows 10 Enterprise 64 1701
    Network RouterAsus AC88U
    Oct 2014
    106
    Question Z370 on Hero/Formula with 8700K and NVMe drives in regard to PCIE lanes - clarify pls
    I need some clarification on this:
    I'm planning to build an 8700K machine on an Maximus X board (any) but I'm not sure about usability since I plan on using two GTX TITAN V cards, two Intel 900P NVMe drives or a single Intel 900P and a Samsung 960 Pro M2 drive.
    No, I know there is no SLI for those Titans, but I don't need SLI, just two cards (rendering).
    Since 8700K provides only 16 PCIE lanes, I assume dual TITAN Vs will split dual PCIE slots into x8 + x8, which is fine. But, what about my Intel drives or Intel + Samsung? Those can run on a PCH which has only a single x4 connection to the CPU so actually, the only available performance to the whole PCH is x4 level and I can use only a single NVMe drive concurrently, not more.
    Right?
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    With 2 GPU's using all of the CPU pcie lanes as you state you can use one nvme drive on the 4x pcie lane, the bottom pcie slot off the PCH, and one or two M.2 nvme drives off the PCH.
    I have a single Titan Xp at 3.0X16, an Intel 900p on the bottom pcie slot at 3.0X4 and a Samsung 960 Pro in M.2 slot at 3.0X4, and 2 SATA drives one 1TB 850 EVO and one 4TB spinner on my M X Apex. Everything operates at full speed smoothly
    So everything will work fine but in my opinion if you need 2 Titan V cards for rendering a X299 platform would still be better suited and allow upgrade path as far as CPU's, GPU's, and storage solutions
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    17
    1,557
    I agree with mentol.
    Even that 8700K is a good processor, it has limitations. you can get around some hd/ssd isuess iwth external drivers. but 1 limitation. is pcie lanes. if you go with x299 7820x is the same issue. but you can grow. IF you want to take the full power of those titans you need more. there is gamer stand of point and productivity side. 7900x is a good all you will have all the power you need. A friend of mine have these same questions. and he is happy have the best of the productivity and have the game with he needed. beside..... you can do 4k gaming in surround without a sweat. And if you water cool those, there is no limit. IF! you do 1 gpu like my my other friend, he work with blender, and cinema4d works but really put the computer into the limit i mean a limit that cpu is 100% with gpu to the max and is slowing down some times and that is until finish the render the computer is useless. 8700k 1080tioc (asus) at 4.8 1.28v. Go with x299. having a sli titans is real power! and have spare to do more
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    More and more it seems moving from 4.7 5960X to 8700K will be a sidegrade or a dowsngrade, rather than upgrade.
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    The 8700K on a good Z370 board can't be beat for gaming and most tasks, it only lacks in pcie lanes, if it fits your needs you will be happy with how fast it is.
    Dual Titan V's won't loose much bandwidth at X8 lanes and a single Titan V will run any game at any resolution without issue. It's really a decision you will have to make
    If you can live with drive specs as I listed you will like how fast the system is
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    Quote Originally Posted by Menthol View Post
    Well, I know; I actually asked for real-life observations and a scheme for the board design. I assumed PCH connects by a single x4 set, which means we have 20 PCIE lanes at disposal: 16 direct, 4 for PCH, which can balance multiple devices, but essentially communicates across x4 only. That means, two PCIE drives would share 4 PCIE lanes and would not work as expected simultaneously.
    I'm trying to avoid X299 for multiple reasons. I currently own R6E+7980XE, overclocked to 4.2GHz, but I'm fully dissatisfied with the mesh architecture since that and the new cache design are killing my performance, being worse for my workload (I profit from cache size, inter-core comm) and I also often need single-core to perform as best as possible. At the same time, I really need fast storage.
    The plan was to move my secondary workstation to be 8700K instead of 5960X. I'll keep using 7980XE for heavy MT workloads, but these are not my core target.
    Do you know of any real benchmark with 8700K that uses 2 cards and an NVMe or two NVMes?
    But you have a single card so you're using 16 lanes with your Titan plus two PCIE drives. That's still 8+4+4. Need something that goes beyond. Dual cards to use 8+8 up, and then two drives contending for x4 on the PCH...
  7. #7
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    My GPU operates at X16, all my NVME drives are on the PCH
    Intel is claiming 40 available pcie lanes, "marketing", not completely a lie
    Z370 PCH has 20 pcie lanes for USB, SATA, NVME, Wifi, etc. so multiple nvme drives can all run at 3.0X4, the only bottle neck is the DMI 3.0X4 buss between CPU and PCH, which is not really an issue unless you are moving massive amounts of data between drives
    So depending on how many M.2 slots the board has, usually 2 on ASUS boards, plus the one X4 you can use 3 NVME drives without affecting the 16 lanes from the CPU for Video cards
    I am running a binned delidded 8700K at 5.2 GHZ -2 AVX offset, 4.8 GHZ cache, 16GB memory at 4266 MHZ 17-18-18-38-1, using a 280mm AIO, no HEDT platform can match that, it is the fastest smoothest running system I have ever owned.
  8. #8
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    Yes, sounds nice, although I've seen 7980XE@5GHz and 4.1GHz RAM HEDT system which definitely has no reason to shy from the slightly faster 5.2, especially since quad-channel enables double the bandwidth per clock on HEDT.
    Still, the cost is significantly lower for 8700K.
    What AIO you're using to cool a 5.2GHz 6-core? Is that 1.35V running? Max RPM under load? Temps?
  9. #9
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    Corsair H115i with ML fans on motherboard fan headers standard mode fans run at approx. 700 rpm idle 1500 rpm max. pretty quite during normal use. CPU is a 5.3 @ 1.437 volts Silicon Lottery binned, I am running 5.2 @ 1.4 volts 24/7
    Quad channel memory does equal much more bandwidth, a 7980XE at 5.0 all core OC is a rarity and will have a much more costly cooling requirement, a 7900X @ 5.0 is more realistic but still a rarity
    I didn't mean to directly compare a Z370 to HEDP platform as they are a different beast, I do own a R6Apex and 7980XE that I only use for 3D benchmarks (waiting for new GPU's this year), 4.8 to 4.9 GHZ all core OC using a water chiller to keep it cool, 3.2 cache, 4000 cl17, non delidded at the moment, I have no real use for HEDP except as a toy to play with
  10. #10
    orcinus PC Specs
    MonitorDell UP2715K
    Mouse Logitech G900
    Oct 2014
    106
    I see... also, 4.9, what voltage? - 5.0 exclusively with a chiller. I can't run my 7980XE above 4.7 and cool it at the same time. It's impossible at load. But I've seen reports.
    Regarding 7900X, funny thing is, 7980XE clocks much better than 7900X. I presume it's the die area thing - 7980Xe comes from a higher core count die process and is less hungry and less packed).
    It's impressive to hear that at 700RPM H115i cools it fine.
Tags for this Thread
