[HELP] Sonic Studio 3 - front and back audio output
Oggy1985
I have downloaded and installed only the latest audio driver for the motherboard (Version 6.0.1.8339, 2018/01/22). I didn't find where to install SupremeFX drivers (if there are any for the board).
In the Sonic Studio 3 I can't find the option to adjust where the sound will go in either BASIC or ADVANCED options. Currently when I plug in my headphones in the front panel the audio is routed only to them and speakers have no sound. I would like to have audio on both devices simultaneously.
Also, in Windows Sound >> Playback devices both speakers (2.0) and headphones (Sennheiser HD599) are listed as one device(Speakers, Realtek High Definition Audio). Is there a way to separate front and back analog audio outputs?
12 REPLIES 12
djbeatstyling
u need the black speaker icon on the right side on your taskbar when opened on the program click the cog wheel and there is ur setting u need
I don't have the black speaker. I have windows 10 audio settings/speaker and Sonic studio (Red square with grey S). What does the black speaker open? What do I need to install to get the black speaker on the taskbar?
Realtek audio driver
take the one on asus site works the best
https://www.asus.com/Motherboards/ROG-CROSSHAIR-VI-HERO/HelpDesk_Download/
I have downloaded the latest audio driver (Version 6.0.1.8339, 2018/01/22) from the site but it has no black speaker icon nor do I see any cog wheel. This is all I have:
Taskbar screenshot
Sonic studio 3 screenshot (basic)
Sonic studio 3 screenshot (advanced)
In both basic and advanced Sonic studio 3 I have only "Speakers" which are one device for both the rear and front motherboard audio. I would like to have separate control of the front and back audio.
i mean this one
71496
Thank you for the reply. The thing is I don't have the menu. How/where did you get the SupremeFX driver for the motherboard?
When I downloaded and installed latest Windows 10 64-bit audio driver (Version 6.0.1.8339, 2018/01/22) it installed Sonic Studio 3 and Sonic Radar 3, but I don't have SupremeFX nor the black (Realtek) speaker. When I search the C: partition there is no SupremeFX installed.
I have a Realtek folder under "C:\Program Files (x86)\Realtek" but it doesn't have the SupremeFX nor a process which would enable Realtek access in the taskbar.
I also have another Realtek fonder under "C:\Program Files\Realtek\" but that one also doesn't have the elements.
Please help how to get the SupremeFX 😮
*Bump*
I have downloaded and installed the latest audio driver (Version 6.0.1.8339, 2018/01/22) for the ASUS Crosshair VI Hero x370 motherboard. The driver installed only Sonic Studio 3 and Sonic radar 3. Where can I get the SupremeFX driver for the motherboard? (If there is any).
Does anyone have the SupremeFX installed for the motherboard? How/where did you get it?
this is wierd because realtek driver should have installed that also have tried to total unistall and then install again i prefer Revo unstaller for total uninstall
and u may try driverbooster its free on steam
