GL553VE Gaming Center Help, no longer opens
korben_drake
Hello, I have a GL553VE with GTX 1050ti 4gb intel core i7-7700HQ 16GB RAM DDR4
Whenever I try to open the gaming center with either the ROG key or the program itself, it pops up in the bottom right corner "Initializing..." and goes away.
Normally the gaming center would them open as normal, but recently it stopped doing so.
In the task manager the ROG gaming key (32) is running.
My ROG aura core works just fine, but the gaming center no longer opens.
StarJack
Level 11
I've had this problem before and the way I solved it it was creating a new windows user profile. It may work for you too.
StarJack
Sent from my SM-G925W8 using Tapatalk
davemon50
Level 11
New user profile sounds extreme and a workaround. Why not try a reinstall?
Davemon50
