Results 1 to 7 of 7
    New ROGer Array GMHVF6 PC Specs
    GMHVF6 PC Specs
    MotherboardAsus Rampage III extreme
    ProcessorIntel I7-950
    Memory (part number)Patriot Sector 7 Viper 2
    Graphics Card #1Asus ROG STRIX 1070 OC
    Monitor27" Phillips LED
    Storage #1Intel 540 128GB SSD
    CPU CoolerThermaltake
    CaseThermaltake Armor +
    Power SupplyThermaltake Toughpower 875W
    Keyboard Logitech G19
    Mouse Razor Mamba
    Headset Plantronics RIG500
    Mouse Pad Razor Goliathus
    OS Windows 10 Pro 64 Bit
    Jul 2017
    5
    Rampge III extreme wierd booting issue
    Senario:
    Went to turn PC on. it flicked on then off straight away then back on again attempting to boot. the red CPU led on the QLED panel lit up solid and no video. Restart and power (holding the power button) didnt work. So had to flick switch on PSU. Same issue each time i booted. tried removing ram and GPU same issue with no video and CPU light on. testing voltage there was 0v at the CPU pin test point. I thought i worked it out to be a faulty Riser cable. plugged card direct into mobo and it booted. I then plugged the riser cable back in and it booted. But all games running max at 20FPS. So i thought great ive confirmed a dodgy riser cable. Card back directly in the mobo, PC booted fine and all games back to 100+fps. Left the PC on overnight and the whole next day no issue. Came back this morning. Exact same thing happened as what initially did, PC flicked on then off (3 times in a row this time) but now the DRAM led lit up solid. i unplugged the USB headers, HDDS and still wouldnt boot. unplugged the gpu same thing, put gpu back in, and now its booted and running fine again.
    Also noteworthy when it actually finally boots my OC settings in bios are back to default.
    So what am i looking at here. Faulty CPU/MOBO/GPU are what im guessing is the list to check.
    PC SPECS
    Rampage 3 Extreme
    I7-950 @3.06 (OC to 3.7 usually)
    Thermaltake Floe Riing 360mm AIO (1 month old)
    Patriot DDR3 sector 7 (6x2GB)
    Asus Strix 1070 (2 months old)
    Corsair HX750i (2 months old)
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,378
    How old is the CMOS battery on the board?...maybe replace it...
    GMHVF6 PC Specs
    Mouse Razor Mamba
    Jul 2017
    5
    Quote Originally Posted by Arne Saknussemm View Post
    still the original from when i first built the pc. 2008
    Apr 2012
    481
    13,378
    I would try changing it for a new one...you might be losing BIOS settings due to bad battery...
    GMHVF6 PC Specs
    Mouse Razor Mamba
    Jul 2017
    5
    just pulled it out to test. sitting on 3.27V and the pc actually still started with it removed. wierd
    Apr 2012
    481
    13,378
    OK...well, I guess you'll just have to keep testing stripping components...keep everything as simple as possible...no riser...maybe test your RAM sticks one by one...
    Have you been running the same RAM always?
    Substitute the PSU for an old one if you still have one about...check cables and pins in sockets and cables
    Check the cooler is mounted with even pressure and not too tight...
  7. #7
    TeamROG Folding@Home Array ottoyu34 PC Specs
    ottoyu34 PC Specs
    MotherboardMaximus IX Hero
    ProcessorIntel Core i7 7700K
    Memory (part number)Trident Z RGB (F4-3600C16D-16GTZR)
    Graphics Card #1ROG Strix GTX1080 Ti OC
    MonitorLG IPS LED 27"
    Storage #1Samsung SSD 850 PRO 1TB
    Storage #2Crucial MX300 525GB SSD
    CPU CoolerCorsair Hydro H115i
    CaseCorsair Obsidian 750D Airflow Ed.
    Power SupplyEVGA SuperNOVA 750 G3
    Keyboard Corsair Vengeance K65
    Mouse Logitech G502
    Mouse Pad Razer Destructor
    Headset/Speakers Logitech Z-2300 2.1
    OS Windows 10 Pro x64
    Network RouterAsus RT-N66U
    ottoyu34's Avatar
    Apr 2010
    805
    Try having ram installed in different config, for ex, one stick only or, 3 sticks on another set of slots.
