Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    99
    932
    Bykski A-Ryzen-Th-X / Bykski A-Ryzen-ThV2-X
    Purchased from Aliexpress, on visual inspection seems like was worth the wait coming from far east . This should be an improvement over the EK-Supremacy EVO Threadripper Edition.
    RGB is not my cup of time but the store that had the best price sold the product with Bykski RGB/AURA . So loose in parcel was Bykski RGB unit, it has 6 connectors, 3 per long side of unit, each with 6 pins, labelled as fan 1 to 6. One short side has 2 connectors with 4 pins labelled as RGB. Other short side has DC 12V 2 pin to molex with pass through, 5 pin labelled as IBM, which has 3 wires to a LED in metal casing . No manual in box and no idea on usage, nor was there a plan to use it TBH .
    Bykski A-Ryzen-ThV2-X has a nice weight and good finish IMO . This V2 edition also supports AM3/AM4 as well as Threadripper, read and weep EK . 3 sides are clear and one long length has an integrated LED unit, this has 4 pin connector and 50cm of cable. There seems to be an 4 pin extension cable included or maybe part of Bykski RGB unit . Cold plate has a fine machined finish, I may lap it at some point, doesn't seem too shabby at all. Looking forward to plumbing this in and comparing to EK .
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH EXTREME
    ProcessorTHREADRIPPER 1920X
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    481
    13,400
    I like it!
    I'm like you and not into the whole disco PC thing, so most of the cables would be off to recycling...but the block itself looks sweet.
    Interested to see results when you get it in the loop...but looks like it will do the job...nice design
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    99
    932
    Cheers .
    The photos do not do it justice, it really looks way better product than the EK standard TR block IMO. It has more of a WOW factor and I swear it feels heavier, but it has been 4-5mths since I held the EK block. I will do a weigh in prior to the bout between them! .
    Apr 2012
    481
    13,400
    Quote Originally Posted by gupsterg View Post
    will do a weigh in
    Ace!
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    99
    932
    Weigh in I forgot . Gonna weigh EK block now as it's off and weigh Bykski on next removal.
    When I fitted EK block I spread TIM on IHS using plastic card (like I've always done on other CPUs) and filled the screws on block with TIM.
    On removal to fit Bykski all looked good to me.
    Used same TIM spread method, install was simple and easy. I used the screws with full thread on their length, as the others were too long (maybe for AM3/AM4 ). RGB on board had been set static RED back in Sep 17 and CPU block lit up as that straight away. Glow is nice and even, intensity does not seem out of place compared with board RGB.
    Above picture there is air bubble top left corner of block, I ran PC for ~12hrs at 100% pump speed to remove air bubble. Preliminary comparison to EK I have gained ~10% drop in CPU temp, this is inline with HardOCP testing as on these pages, link 1 and link 2.
    The Bykski A-Ryzen-ThV2-X was ~£44 delivered, EK-Supremacy EVO Threadripper Edition (Plexi/Nickel) £60 (source was FOC delivery). The Bykski wins hands down IMO on:-
    • Performance
    • Features
    • Price
    • Visual appeal with and without RGB IMO
    What it loses on is zero support from manufacturer and source, the included "manual" had ~6 differing Bykski block install info but this one (IIRC).
    Apr 2012
    481
    13,400
    • Performance
    • Features
    • Price
    • Visual appeal
    So, it was close eh?
    LOL sounds like a good move! Looks like a good move..like the look of that block way better!
  7. #7
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    99
    932
    Indeed looks much more appropriate than EK block.
    Cooling:-
    EK XRES 140 REVO D5 PWM
    2x MagiCool G2 Slim 360mm
    Each rad 3x Arctic Cooling F12 PWM
    Mayhems XT-1 Clear concentrate ~20% with distilled water
    Arctic Silver 5 TIM
    Custom profile, controlled by ASUS ZE based on loop temp (T_Sensor1). Housed in Be Quiet Dark Base 900, front modded to mesh, top panel modded to allow more air exhausting at side mesh, chassis sealed between top panel so no back draft from exhausting fans occurs, Be Quiet 140mm 1K RPM as exhaust on case, set 100% static.
    Room ambient ~23C when EK test was done (top screenie), ~22C when Bykski tested (bottom screenie). EK block had been fitted for ~5mths, so fully cured, Bykski ~2 days on. Prime95 v29.4B8, custom in place FFT 12K 12K.
Name:	P95 v29.4b8 12K inplace 39 1.3V 1.081V 1.385V 60 24 24 24 24 23C 22C EK vs Bykski.jpg
  8. #8
    Apr 2012
    481
    13,400
    Nice...easy 5 degrees already
  9. #9
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    99
    932
    Indeed.
    Stock CPU EK (top) vs Bykski (bottom), IMO room ambient variance +/- 1-2°C, P95 custom 12K 12K in place FFT.
Name:	P95 12K stock EK vs Bykski.jpg
    As the Bykski mount is not spring loaded I nipped it originally tightish, now TIM has had some cycles of usage I decided this morning it was time to recheck screw tightness. They did turn again with ever so slight resistance, so I gave each ~1/4 turn.
    Since originally building the loop I had planned to shorten/neaten up the tubing between lower rad and pump/res, when I do this I will hopefully lap the Bykski block and see what occurs .
    The EK block is weighing in at ~324g as out of the box. I may weigh just the cold plate, but IMO I think the Bykski will still have more mass. Below photos from HardOCP reviews of each block.
Name:	HardOCP splat EK vs Bykski.jpg
    The Chinese offering is defo giving more for your $/£/€ besides other aspects .
  10. #10
    Apr 2012
    481
    13,400
    Without a doubt! Any design that gives high even flow over the ENTIRE die surface area will be a winner...
    EK simply didn't manage the basics...maybe underestimated TR popularity...
