Results 41 to 50 of 69
09-11-2018 01:56 AM #41
- Join Date
- Feb 2018
- Reputation
- 10
- Posts
- 5
Just another follow up. I found fiber optic lines on amazon for 5 bucks. I purchased 5mm initially which was too big, so I got 3mm which was slightly too small (but works good enough). I believe 4mm would be the ideal replacement. Took me about 5 minutes to replace it. Just removed the existing tubing (being careful not to break any of the plastic tabs), cut the new one to length using cat nail clippers, and installed it. Definitely looks way better now. Good luck everyone! This is definitely not worth an RMA, especially given ASUS's reputation with their RMA department. 5 bucks and 5 minutes and we're good as new.
10-01-2018 08:02 PM #42
- Join Date
- Jan 2015
- Reputation
- 10
- Posts
- 2
Info for people having problems with their fan shroud lighting.
The side glow fiber optic conduit is 4mm.
link to Ebay listing for replacement. comes in 12 inch sections so you will need 2
https://www.ebay.com/itm/Fiber-Optic...72.m2749.l2649
10-16-2018 07:13 AM #43
- Join Date
- Oct 2018
- Reputation
- 10
- Posts
- 1
I have the same problem. I used RMA from Amazon and the send me a new graphic card
10-19-2018 05:39 PM #44
- Join Date
- Apr 2017
- Reputation
- 10
- Posts
- 3
I had the same issue with an Asus ROG Strix 1080ti and ended up buying a 1M long 4mm light tube from eBay for $5. It took 4 weeks to get here but the repair took 5 minutes. Here are the before and after with a picture of the light tube I bought.
The picture with the fan shroud dissembled shows the old tubes that have turned milky white on the right. The actual LEDs are the 2 at the top of the picture.
The actual eBay part is here https://www.ebay.com/itm/1M-PMMA-Sid...72.m2749.l2649
11-05-2018 10:31 PM #45
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 2
I thing i found a sulution
Hello everyone I think i foud a salution to thins problem. The LED its not falty its the tube its self, over the time from the light the tube is getting like milki brown ish and the tube have to be replaced. Here is what i thing ASUS used (https://www.amazon.co.uk/dp/B0797M9F...a-458192585722) i have the same issue ill order it and see if that makes any difference.
11-05-2018 10:46 PM #46
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 2
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 here is a link to new optic fiber tubes that will fix the problem
11-24-2018 06:21 PM #47
- Join Date
- Sep 2014
- Reputation
- 10
- Posts
- 34
Anyone have a guide on how to take off the cover and replace it?
11-29-2018 05:30 PM #48
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 1
There is a video link on a couple pages back shows the whole tear down process.
01-15-2019 08:21 PM #49
- Join Date
- Sep 2018
- Reputation
- 10
- Posts
- 2
Hello all
I am having the exact same problem but with a graphics card ROG-STRIX-RX580-T8G-GAMING I read a lot about the graphics card before buying and I read that lighting works well for eight yearsBut now I have this ridiculous holiday after a year and a half
It seems to be a bug in all graphics cards
You have ordered this purchase https://www.amazon.de/gp/product/B07...?ie=UTF8&psc=1
Thank you to the owner of the subject and to all those who contributed to solving this problem, but I did not know what to do
01-23-2019 09:37 AM #50
MrAgapiGC PC Specs Motherboard Asus Maximus XI Code Processor 9900K Memory (part number) CMK32GX4M4B3600C18 Graphics Card #1 STRIX-GTX1080ti-O8G-GAMING Monitor AOC AGON AG2701QX (2) Storage #1 Samsung 960 EVO 256GB Storage #2 Kingston Savage 500GB CPU Cooler Nzxt X74 360mm AIO Case Nzxt H700 Power Supply EVGA 850 G2 Keyboard Logitech G810 Mouse Asus Spartha Headset Hyper X Cloud Revolver S Mouse Pad Hyper X Fury S 900mx420mm Headset/Speakers Logitech Z337 OS Windows 10 64btis Network Router TpLink Archer C9 Accessory #1 EKWB FANs all of them
- Join Date
- Nov 2011
- Reputation
- 27
- Posts
- 1,778
We have also 1 card with the same issue. a 1080ti. is no the led. Since we do not have a Asus service center. I have to get another front facia plastic to make a change and give that one to my friend. I am trying to get one but no where to get one. I will tell the guy to order that part from amazon and see what we can do. Here in Panama once pass the year of warranty is a pain. taking that out is just 6 screws and have to be done easy since 3 of them are in the back of the fans.
