The ROG Cetra Open Wireless Gaming Earbuds combine low latency with open-air freedom
The best earphones are the ones you’ll actually use — which means comfort, portability, and convenience features are paramount when choosing a pair of on-the-go ‘buds. And if you’d prefer a pair that doesn’t sit inside your ears, the ROG Cetra Open Wireless Gaming Earbuds might be just the ticket.
Comfort and convenience take center stage
Unlike most earbuds, which feature silicone tips to create a full seal inside your ears, the ROG Cetra Open Wireless feature a small hook that rests over them instead, with 14.2mm Diamond-Like Carbon Drivers pumping high-quality audio into your pinna. For folks who don’t like the feeling of something lodged in their ear canal — or people who want a bit more situational awareness — this design offers an incredible sense of comfort and utility. Whether you’re out for a jog or gaming on the train, you’ll be able to hear all your audio without completely blocking out the world around you.
The comfort is astounding, but we don’t sacrifice audio quality to get there. The drivers offer excellent clarity and detail, with low distortion and two selectable sound modes for customization. Phantom Bass mode enhances the perception of low-end frequencies, while Immersion Mode uses ANC-like tech to reduce background noise despite the open form factor, allowing you to focus more on your gameplay or music.
Finally, a detachable reflective neck strap adds a bit of security when you need it, while a Quad-Mic layout with AI Noise Cancelation adds clarity to your calls and in-game comms alike. And with up to 16 hours of battery life on the earbuds themselves (with a total of 64 hours including the case) and IPX5 splash resistance, you’ll be able to keep listening anytime, anywhere.
Low-latency audio makes no compromises for gaming
If you’re a gamer, most earbuds lack one crucial feature: low latency audio. Most wireless protocols like Bluetooth feature an inherent delay, which is fine if you’re just listening to music and podcasts — but murder if you’re trying to play a game. (Literally, you’ll get murdered on the virtual battlefield when your audio cues don’t match up with what’s on-screen.)
That’s why we built the ROG Cetra Open Wireless with dual-mode wireless connectivity: Bluetooth when you want a quick and convenient connection, and an ultra-low-latency ROG SpeedNova 2.4GHz wireless connection when you’re jumping into a game. The USB Type-C wireless receiver contains its own USB passthrough, so you can still charge while you listen, with no discernable delay between on-screen action and the sound that hits your ears. It’s the best of both worlds.
The perfect companion to your phone, laptop, or ROG Ally
When you’re on the road listening to music, watching movies, or playing games, you need a pair of earbuds that actually fits your use case. Traditional earbuds with their high latency are a no-go for gaming, but ROG has your back. If you want traditional in-ears with loads of features, check out the ROG Cetra True Wireless Speednova — but if comfort, convenience, and open-air audio are what you’re about, the ROG Cetra Open Wireless are the ultimate match for your mobile gaming devices. Check with your local ROG representative for pricing and availability.
Popular Post
What GPU should you choose for your gaming laptop? RTX 5050 vs 5060 vs 5070 vs 5070 Ti vs 5080 vs 5090
The ROG Raikiri II is my new go-to game controller — and I can’t put it down
Meet the ROG NUC 16: compact power for gaming, AI workloads, and beyond
If you’ve never gamed on an open-back headset, it’s time to level up your audio
The best earphones are the ones you’ll actually use — which means comfort, portability, and convenience features are paramount.
How to choose a gaming headset in 2026: competitive FPS, immersion, and streaming explained
All ROG headsets are great for gaming. So the question is: which one's best for you?
With an open-backed design and audiophile quality sound, the ROG Kithara is unlike other gaming headsets. But is it right for you?
