ROG triple-mode gaming monitors level up with 4K panels and up to 920Hz refresh rates
Every game demands something different. AAA blockbusters stuffed with detail reward razor-sharp 4K visuals, while esports titles are all about pushing frame rates as high as possible to keep up with opponents. Some games fall between these poles and benefit from a balance of high-resolution imagery and equally high refresh rates. With the latest triple mode additions to the ROG Strix lineup, you’ll have a gaming monitor built to handle each kind of experience without compromise.
Meet the ROG Strix XG27UCMG and ROG Strix XG27ACNS: two 27-inch gaming monitors built around our latest triple mode technology, giving you the flexibility to prioritize stunning image quality, uncompromising esports performance, or a balanced profile with just a few clicks. Whether you're exploring massive open worlds in ultra-high resolution or chasing every last frame in competitive shooters, these displays are ready to adapt to the way you play.
The ROG Strix XG27UCMG unites 4K glory and triple‑mode versatility
When you want a display that can do it all — uncompromising resolution, elite refresh rates, and flexible performance modes — the ROG Strix XG27UCMG has you covered. This 27‑inch 4K IPS powerhouse delivers stunning detail at up to 4K 240Hz, giving you the image clarity of a high‑end creator display with the speed of a proper esports panel. And when you want even more frames for tournament-grade play, switch to QHD 400Hz (OC) or FHD 488Hz (OC). Triple‑mode flexibility lets you choose the perfect balance of resolution and refresh rate for every game in your library.
The XG27UCMG brings vibrant visuals with 95% DCI‑P3 coverage and VESA DisplayHDR 400, ensuring your game worlds look as rich and lifelike as they feel. With ASUS Smart Pixel technology, even lower‑resolution content gets enhanced clarity and sharpness, making this monitor a beast for both high‑end gaming and everyday use.
Connectivity is equally versatile: DisplayPort 1.4 (DSC), HDMI 2.1, USB‑C with 15W power delivery, and dual USB 3.2 Gen 2 Type‑A ports give you everything you need to hook up your gear. A built‑in KVM switch with hotkey control makes it easy to manage multiple systems from a single keyboard and mouse, perfect for creators, streamers, and hybrid setups.
DisplayWidget Center gives you a better monitor experience with automatic firmware updates and the ability to export, import, or copy pro‑streamer monitor settings with ease. And the XG27UCMG packs our ROG Gaming AI technology, including AI visual enhancements like Dynamic Shadow Boost and Dynamic Crosshair. These tools help you see enemies in dark spaces, have clearer aim on the battlefield, and more.
The ROG Strix XG27ACNS pushes QHD speed to the extreme
If raw speed is your priority, the ROG Strix XG27ACNS is ready. This 27‑inch QHD monitor features triple‑mode tech that lets you choose between QHD 475Hz (OC), FHD 620Hz, or HD 920Hz. Whether you’re grinding ranked matches or going to tournaments where frame-perfect plays are essential, this display gives you the headroom to push your skills to the absolute limit. With up to 920 frames visible every single second, you’ll never have to worry about being behind the curve.
A Fast IPS panel with 0.3ms (min) GTG response time keeps ghosting to a minimum, ensuring every flick, swipe, and snap feels crisp and immediate. The XG27ACNS delivers 95% DCI‑P3 color and VESA DisplayHDR 400, so your games' visuals are presented vibrantly and accurately.
Connectivity includes DisplayPort 1.4 (DSC), HDMI 2.1, and USB‑C with 15W power delivery, giving you flexible options for gaming laptops, desktops, and portable devices.
This monitor benefits from DisplayWidget Center for auto firmware updates and easy profile management. And you’ll also get ROG Gaming AI technology for AI visual tuning, Dynamic Shadow Boost, and Dynamic Crosshair — all designed to help you see more, react faster, and stay locked in.
For information on the pricing and availability of the ROG Strix XG27ACNS and ROG Strix XG27UCMG in your region, please contact your local ROG representative. And for a complete rundown of ROG’s Gamescom 2026 reveals, check out our big roundup.
OLED Dual mode monitors
| Model | Size | Panel Type | Resolution Priority Mode | Refresh Rate Priority Mode |
| ROG Swift OLED PG32UCWM | 32" | Tandem RGB OLED | 4K 240Hz | FHD 480Hz |
| ROG Swift OLED PG27UCWM | 27" | Tandem RGB OLED | 4K 240Hz | FHD 480Hz |
| ROG Strix OLED XG32UQWMS | 32" | Tandem WOLED | 4K 240Hz | FHD 480Hz |
| ROG Swift OLED PG27AQWP-W | 27" | Tandem OLED | QHD 540Hz | HD 720Hz |
| ROG Swift OLED PG27AQWP-G/ PG27AQWP-GR Edition 20 | 27" | Tandem OLED | QHD 540Hz | HD 720Hz |
| ROG Strix OLED XG32UCWMG | 32" | OLED | 4K 240Hz | FHD 480Hz |
| ROG Strix OLED XG32UCWG | 32" | OLED | 4K 165Hz | FHD 330Hz |
IPS Dual mode monitors
ROG Strix XG27UCG Gen 2 (XG27UCGR) |
27" | Fast IPS | 4K 162Hz | FHD 485Hz |
ROG Strix XG27UCS Gen 2 (XG27UCSR) |
27" | Fast IPS | 4K 160Hz | FHD 324Hz |
| ROG Strix XG32UCG | 32" | Fast IPS | 4K 160Hz | FHD 320Hz |
| ROG Strix XG27JCG | 27" | Fast IPS | 5K 180Hz | QHD 330Hz |
| ROG Strix XG27JCEG | 27" | Fast IPS | 5K 80Hz | QHD 320Hz |
IPS Triple mode monitors
| Model | Size | Panel Type | Balanced Mode | Turbo Mode | Hyper Mode |
| ROG Strix XG27UCMG | 27" | Fast IPS | 4K 240Hz | QHD 400Hz | FHD 488Hz |
| ROG Strix XG27ACMSR | 27" | Fast IPS | FHD 420Hz | HD 640Hz | FHD 420Hz |
| ROG Strix XG27ACNS | 27" | Fast IPS |
QHD 475Hz |
FHD 620Hz | HD 920Hz |
| ROG Strix XG27ACMESR | 27" | Fast IPS |
QHD 280Hz |
FHD 365Hz | HD 550Hz |
Popular Post
Can I use a gaming laptop for work?
What GPU should you choose for your gaming laptop? RTX 5050 vs 5060 vs 5070 vs 5070 Ti vs 5080 vs 5090
The ROG Gladius IV Ace gaming mouse delivers next-level ergonomics and precision
20 years in the Republic of Gamers, part four: tempered glass and synchronized light spark a design revolution
The ROG Spatha X 65K gaming mouse gives you total control over your favorite MMOs
New 24.5-inch ROG monitors bring OLED panel tech to the esports arena
Esports enthusiasts, your wait is over. ROG is bringing game-changing OLED visuals to the monitor size preferred by many professionals.
Our new triple-mode gaming monitors offer three resolution and refresh rate combinations to satisfy the visual needs of every title in your library.
Glossy, semi-glossy, or matte? Choose the right OLED gaming monitor for your setup
OLED monitors with glossy, semi-glossy, and matte coatings can all be good options — it just depends on the way you like to play.
