The ROG Strix OLED XG32UQWMS unites a 32-inch Tandem WOLED panel with great value
Tandem technology comes to the Strix XG series with the ROG Strix OLED XG32UQWMS. This UHD display marries Tandem WOLED glory with our dual-mode Frame Rate Boost technology, giving you next-level fidelity and versatility. With exceptional brightness, color volume, and glare suppression, this 32-inch stunner is ready for all your gaming, media, and content creation needs.
Dual-mode Tandem WOLED technology for every win
The XG32UQWMS's Tandem WOLED tech means your screen has two layers working together to give you 15% brighter imagery and 25% larger color volume than previous gen WOLEDs. In essence, it takes what’s great about a panel like the ROG Strix OLED XG32UCWMG’s and levels it up. Tandem tech also gives your screen a 60% longer lifespan, helping combat long-term brightness degradation and burn-in risk.
To augment your Tandem experience, we’ve armed the XG32UQWMS with a TrueBlack Glossy coating. This gives the panel a zero-haze surface so you can enjoy exceptionally sharp imagery, while still suppressing glare and unwanted reflections — letting inky blacks shine through no matter your gaming space’s lighting situation.
Pair these fidelity-enhancing perks with up to 1,500 nits of peak brightness* and 99.5% DCI-P3 color, and you’ve got a recipe for incredible HDR. We’ve calibrated this monitor at the factory for a Delta E < 2, and it’s VESA DisplayHDR 500 True Black certified — sowhether you're playing realistic AAA games, watching vibrant HDR content, or editing photos, you know you’re getting rich, accurate colors across the board.
But there’s more to good gaming than gorgeous imagery. You’ll need high resolutions to appreciate the fine details, and you’ll need high refresh rates to see them all with silky smooth motion. Rest assured, whether you need to max out sharpness or fluidity, the XG32UQWMS is here for you. Flip a switch to choose between 4K @ 240Hz or FHD @ 480Hz. The high-resolution mode is perfect for AAA blockbusters where every pixel of stunning detail matters. The high refresh mode gives you a competitive edge in blink-and-you'll-miss-it esports titles, where every single frame can provide game-changing information. Combine that dual-mode versatility with the monitor’s 0.03ms response time, and you have the specs you need for any situation modern gaming throws at you.
*Actual peak brightness may vary between displays due to factory calibration.
Gaming goodness that’s built to last
To protect your OLED investment, we pack the monitor with OLED Care Pro features such as the newly upgraded Neo Proximity Sensor. It automatically switches to a black screen when you step away, minimizing burn-in risk while sparing you the hassle of turning your monitor on and off. And now, you can customize its sensitivity as well as set timers synced to your screen schedule. When combined with the software-based OLED Care features in our DisplayWidget Center app, your panel is ready to stand the test of time.
OLED Care Pro features are just a slice of the software that we use to give you an optimal experience. We also outfit the XG32UQWMS gaming monitor with our suite of ROG Gaming AI technologies. These include Dynamic Shadow Boost, which adjusts shadow darkness in real-time to help reveal sneaky enemies, and Dynamic Crosshair, so your crosshair color remains high contrast and visible no matter what. If you’re using DisplayWidget Center, you can also export and import monitor settings, should you want to share yours or try someone else’s preferred preset.
For even faster tinkering, the monitor’s quick-access OSD menu lets you adjust settings on the fly with ease. It also gives you instant access to Picture-in-Picture (PiP) and Picture-by-Picture (PbP) functions, allowing you to view content from multiple sources simultaneously and even switch between audio inputs. Open a sub-window from a second connected device while keeping your primary content front and center or split the display between two sources at once. Two devices, one display, organized however you see fit.
This next-gen Tandem OLED is ready to connect to all your gear. With DisplayPort 1.4 DSC connectivity, two HDMI 2.1 ports, and a USB hub, you’ll have no trouble hooking it up to your PC, console, and any other device you game on. Its I/O options are ready for your battlestation, just like its features are ready for your unique gaming situation. Whether you want a 32-inch WOLED with Tandem technology, crave dual-mode versatility, or desire all these perks and more in a single value-focused display, the XG32UQWMS delivers.
For more information on the pricing and availability of the ROG Strix OLED XG32UQWMS in your region, please contact your local ROG representative.
Popular Post
Can I use a gaming laptop for work?
The 2026 ROG Strix G16 and G18 raise the bar for gaming laptops once again
The ROG Raikiri II is my new go-to game controller — and I can’t put it down
What GPU should you choose for your gaming laptop? RTX 5050 vs 5060 vs 5070 vs 5070 Ti vs 5080 vs 5090
20 years in the Republic of Gamers, part four: tempered glass and synchronized light spark a design revolution
Six cool things to try after unboxing your ROG XREAL R1 Gaming AR Glasses
Soak in the novelty of having a virtual mega screen, then explore your R1 glasses' wealth of features to unlock the gadget's true potential.
The ROG Strix OLED XG259QWPG Ace is a premium 540Hz esports gaming monitor made with pros, for pros — current or aspiring.
The ROG Swift OLED PG32UCWM combines RGB Stripe OLED with the improved heat management of GaN
With a Tandem RGB Stripe OLED panel, dual-mode technology, and efficient GaN power, the ROG Swift OLED PG32UCWM is ready to level up your setup.
