The ROG Swift OLED PG32UCWM combines RGB Stripe OLED with the improved heat management of GaN
Earlier this year, we announced new RGB Stripe OLED monitors, which combine the brightness and efficiency of Tandem OLED with a true RGB pixel layout for sharper text and improved colors — plus an upgraded Neo Proximity Sensor and Gallium Nitride Field-Effect Transistor (GaNFET) technology. But one format was noticeably absent from the lineup: an immersive 32-inch display ready for AAA games and esports of all kinds. Today, we’re happy to announce the ROG Swift OLED PG32UCWM, which will launch alongside its 27-inch sibling later this year.
As a dual-mode monitor, the PG32UCWM allows you to effortlessly switch between 4K at 240Hz or FHD at 480Hz, allowing you to choose the best config for graphically-intense cinematic masterpieces and fast-paced shooters alike. Comprehensive IO includes DisplayPort 2.1a UHBR20 with full 80Gbps bandwidth, HDMI 2.1, USB-C with 90W power delivery, and a tripod socket on the stand for all your streaming endeavors.
But as always, the real draw is the picture quality: and that’s where Tandem RGB Stripe tech comes in.
Tandem RGB Stripe OLED brings incredible brightness, color, and clarity
The ROG Swift OLED PG32UCWM features the latest Tandem OLED panel technology, with two light-emitting layers that work together providing brighter performance with less power consumption. This display’s RGB Stripe sub-pixel arrangement offers crisper text without color fringing, as well as more accurate color reproduction with up to 27% larger color volume. And with its TrueBlack Glossy coating, contrast and colors will pop more than ever with incredible detail.
Combined with OLED’s pixel-perfect contrast, the result is an incredibly vibrant image that jumps right off the screen. The PG32UCWM features 1000 nits of peak brightness in HDR, with 99% coverage of the DCI-P3 color space, true 10-bit color, and incredible color accuracy with a Delta E < 2. This gives it a certification of VESA DisplayHDR™ 400 TrueBlack, offering beautiful HDR imagery. Meanwhile, Dolby Vision support offers even more immersion in supported movies, shows, and games. If you want an expansive, realistic image for lifelike HDR, the PG32UCWM is an excellent choice.
The next step in OLED longevity: Neo Proximity adjustments and GaN efficiency
OLED picture quality is second to none, which is why we want this display to last you well into the future. While our OLED Care suite of software provides plenty of protection, we’ve built two special hardware features into this monitor to minimize burn-in risk and keep you gaming for years to come.
The first is an upgraded version of our Neo Proximity Sensor, which precisely detects your presence and your distance away from the screen. When you step away, it automatically turns the screen off to reduce pixel wear. The latest version features an Auto Away Timer and Motion Sensitivity adjustments. If you’re the type of person that gets so locked in to your game that the sensor thinks you’ve stepped away, turning up the sensitivity will help you stay locked in without missing a frame.
The other thing that contributes to pixel wear over time is heat. And while we’ve continually pushed thermal design with custom heatsinks, better airflow, and graphene films, the ROG Swift OLED PG32UCWM comes with another big advancement: Gallium Nitride. This breakthrough allowed us to shrink the footprint of the monitor’s power supply for up to 30% higher efficiency, providing stable, reliable power without excess heat. In fact, when we measured heat coming out of the monitor’s vents, we found that its temperature had dropped by 10% compared to the previous power solution, which means you can rest easy knowing your OLED is ready to go the distance.
For more information on pricing and availability of the ROG Swift OLED PG32UCWM, contact your local ROG representative.
Auteur
Popular Post
What GPU should you choose for your gaming laptop? RTX 5050 vs 5060 vs 5070 vs 5070 Ti vs 5080 vs 5090
The 2026 ROG Strix G16 and G18 raise the bar for gaming laptops once again
Meet the ROG NUC 16: compact power for gaming, AI workloads, and beyond
Laatste Artikelen
Six cool things to try after unboxing your ROG XREAL R1 Gaming AR Glasses
Soak in the novelty of having a virtual mega screen, then explore your R1 glasses' wealth of features to unlock the gadget's true potential.
The ROG Strix OLED XG259QWPG Ace is a premium 540Hz esports gaming monitor made with pros, for pros — current or aspiring.
With a Tandem RGB Stripe OLED panel, dual-mode technology, and efficient GaN power, the ROG Swift OLED PG32UCWM is ready to level up your setup.
