Question on air flow
edub404
I have just a quick question on airflow. I have a coolermaster enforcer case with a corsair H60 push pull config, i am using the 120mm exhaust fan that came with the case as pull and the 120mm that came with the H60 as push.My question is if i turn the 200mm exhaust that i have at the top of the case into a intake do you think i would get better temps.
MOBO - Crosshair V Formula
CPU - AMD Phenom II x4 980 BE 4.2 😄 overclock
COOLER - H60 PUSH PULL
RAM - 8GB G.Skill RIPJAWS X
GPU - HD 6870x2
HDD - 1tb
PSU - Rosewill 630 This PSU is GREAT
CASE - Coolermaster Enforcer
OS - Windows 7 Ultimate SP1 64bit
Simple But Gets The Job Done:cool:
16 REPLIES 16
TenBlade
Level 11
It could, but if front intake air is heated by other components before reaching your pp-setup, then those items may become hotter if a rather straight front-to-back flow is diverted. Perhaps you have the option to add a fan on the side of your case that would blow in the general direction of your radiator?!
edub404
No there is no way to add another fan
GPU - HD 6870x2
HDD - 1tb
TenBlade
Level 11
Then it´s time you venture into modding :cool:
You take off the side panel, make a hole that´ll fit a 120 mm fan, and you´re good to go! Make sure you also get a fan filter, I wouldn´t leave that out.
Zka17
Level 16
Before modding, I still would try to invert the top fan... just to see if it makes a difference in temps...
Also, if you want max performance on your cooler, it's better to have identical fans on both sides... otherwise you just have to calibrate the rpms very well...
Jim-M4EZ
** "Top: 200 mm black fan x 1 (optional ; can be swapped for two 120mm fans)" **
Without knowing the specs on the "stock" top 200mm exhaust fan ...
... I would think that a pair of high quality 120mm fans up top, would certainly outperform the stock 200mm fan.
On the Carbide 500R cases that we use, we junk the stock side mount 200mm fan, for a pair high quality 120mm fans ...
... there's no comparison - the 200mm fan can't begin to keep up with the pair of better quality 120mm fans.
... "heat rises" ... 😉
- M4EZ - 1: 3510 - 2: 1004 / i7-2600K / Redline 2133 16GB / Win7 Pro x64
- v.3510 / 8.0.0.1351 - v.8.1.0.1263 / 10.8.0.1303 - v.11.2.0.1006
- RevoDrive3x2 240GB - OS / Vector 256GB x2 RAID0 - OS / Vertex3 MI 120GB - OS / P'9230 3.0 2TB - B/U
- 9260-8i BBU - CacheCade Pro Vertex3 120GBx2 RAID0 SSD Caching - Const ES SAS RAID10 GHS - Data
- GTX580 3GB HC2 / Xonar Essence STX / ST1200G / TJ10B-W / ZR30w / SP 2500 2.1
- Water: Swiftech/Koolance/Tygon/EVGA/MIPS - Wind: SST/Noctua/Cougar
You believe or not, that doesn't really matter... 🙂 If you have proper airflow on the fans, you can completely invert the the way hot air goes...
In this case, you can set the top fan as intake, just be sure that the rear rad/fan setup can exhaust the air from the top and front fans... actually, the real cool setup would be with the rear rad/fans setup as intake, front intake and top exhaust (if you can change the top 200mm into 2x 120mm, even better)
Area_66
Level 11
no need to reverse it, if it push hot air outside, cold air get inside someplace.
speed
Level 12
Set it up like this and it gets the coldest air in and the hot air out fast.13523
Being ingnorant and ingnored one post at a time.
edub404
Thank you all for your ideas and help i will be trying some if not all ideas.i did try swapping the top exhaust 200mm into a intake and it made no difference in temps.
GPU - HD 6870x2
HDD - 1tb
