Gene-Z speed won't drop when overlclocked
Retired
Not applicable
So I can't get my core speed to drop when idle after overclocking my i5. Any suggestions?
I haven't disable any options like Speedstep etc.
I simplely change the max core ratio to 46 but it stays constant at 46 instead of dropping when idle. Also if I change the ram frequentsy is still constant as well..
Im stumped on this one. Any help?
Retired
Not applicable
Bump. Anyone?
xeromist
Are you sure the setting you changed is a max value? Usually when you are overclocking you are instructing the computer what speed you want it to run. If you have overclocked there is no way for the computer to know what to use for an idle speed.
