Sound dampening
Retired
Not applicable
Hi!
Before spending money on such items, I'd like to know how effective sound dampening solutions, like fan and PSU rubber/silicon pads, are.
Are they worth the money? I'm looking getting the from FrozenCPU.com at about $4 a piece, for all my 5 fans + PSU. Even although it's less than $30 total, I wouldn't like to spend that if it means throwing the money away.
So, from your experience, is it worth getting that?
thanks.
5 REPLIES 5
pcjunkie209
are you getting vibration noises from your fans? because i havent had those issues on any of my builds.
"I would rather be gaming!" Grunts-clan.com
[SIGPIC][/SIGPIC]
http://Pcjunkiemods.com
http://c2cmods.com
xeromist
This can help if you have vibration noises but a lot of the noise comes from the components themselves. For instance in a case that had a nasty fall once I will sometimes get a vibration that stops when I tap the case, but it also has quite a bit of noise from the fans pushing air through the radiator. So it just depends on what kind of noise you are trying to suppress as to how you should go about it.
Retired
Not applicable
Thanks.
Actually I am not getting any noise I can relate to vibration, but on the other hand, I guess that 6 fans (5 case + 1 CPU fan) spinning at high speeds obfuscate any vibration noises I have. So, if I have them, I really don't know!
When I set the 5 case fans to their lowest settings (40% RPM), the PC is just a whisper, so I just wonder if it could be even more silent by using dampening silicon pads & the like.
Thanks again.
ottoyu34
I suggest using slient cooling components instead, such as slient fans and cpu cooler. First, track down the source of the main noise origin. ie, CPU cooler running on high speeds. Secondly, tune down the noise output of the source by reducing speed, replacing it, etc. Depends what you are looking for, you might have tradeoff in cooling & overclocking. Also you might have to replace step 1-2. But sound dampening material is used last just for "icing on the cake", you have to fix the source first. so this is my procedure of sliencing a rig:
1. Fans, Coolers, HDD, PSU (noise sources) replace with slient replacements.
2. Case (some tends to add vibration noise,etc)
3. anti-vibration pads/screws
4. Sound dampening
Usually I go as far as number 2 as many fans I purchase have anti-vibration features.
Also, note that different fan bearings will generate different amount of noise, usually fans comes with cases are sleeve bearings and will generate more noise as they wear out.
coming from a very picky person about noise and only favour slient computing.
Retired
Not applicable
I gave up on my rig being quiet. I have 4 of these wired to both 5 and 12 v using switches and diodes for high and low switches. Using the 12 lead, they get kinda loud!!!
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999612&cm_re=80_mm_case_fans-_-11-999-612-_...
