► (N551JK Sound Problem with Realtek High Definition)
neyestani
Hi ASUS support team
For a long time I wanted to talk about the problem
I bought this laptop from the beginning that I was witnessing the lack of audio playback quality was not good at all
I installed several times and wiped realtek driver
I did not feel any change in this regard,
That voice cracked machines
Low levels of sound quality
And the older environment realtek drivers in this laptop
Realtek Audio Wizard actually does not work properly
That was not what was seen in advertising
You may not believe but I program SRS Labs ™> SRS Audio Essentials ™ application and I'd seen unparalleled quality
Ultra-clear sound and perfect
Just a little noise in the volume of sound on the body of the laptop feel
It really was fantastic :))))
But I wanted to be synchronized with the device drivers realtek
I ask you why your device drivers with devices coordinated helpful?
Where is the problem really?
I hope you check out my problem 😞
Another question?
>> Why do not you update drivers other N551JK laptop. When you start Windows 10*
Thanks
Neyestani.
0 REPLIES 0
