Your Bag is empty.
Your Bag is empty.
Reign supreme with ROG and ROG Strix Z790 gaming motherboards
Intel’s 13th generation of Core CPUs have arrived, and they’re ready for action. Boasting up to eight performance cores and sixteen efficiency cores for a total of 32 threads, and arriving with out-of-the-box support for DDR-5600 and next-gen PCIe 5.0 graphics cards and M.2 SSDs, these chips are sure to draw the eye of discerning gamers—and we’ve got the motherboards you need to unlock their full potential.
For those who dare to build a PC replete with cutting-edge tech and unconventional style, we offer the ROG Maximus Z790 Extreme and the ROG Maximus Z790 Hero. ROG Strix returns to deliver stunning good looks and jaw-dropping performance in four different options. And if you’re looking for mainstream TUF Gaming and ASUS Prime Z790 motherboards, we’ve got those, too. Head over to our full Z790 motherboard guide for all the details.
Intel’s 13th Gen CPUs will hit the shelves on October 20th, but you don’t have to wait to lock in the parts for your build. We’re currently accepting pre-orders for every motherboard in this guide—click here to claim your favorite.
Easy memory optimization
When we first launched our last-gen Z690 family, DDR5 RAM had only recently hit the market. Many builders looked for assurance that their new memory would work as advertised in their new motherboards—and we went above and beyond to make that happen. We collaborated closely with a wide range of industry partners to offer ASUS Enhanced Memory Profile (AEMP), which ensures better and wider compatibility with your favorite brands of RAM.
DRAM slots on the ROG Maximus Z790 Extreme motherboard
Now that the DDR5 market has matured, and a wide range of memory kits are available at increasingly enticing prices, builders are rightly thinking more about performance than compatibility. Once again, we’ve gone above and beyond. For every Z790 motherboard that supports DDR5, we’re introducing AEMP II profiles that offer up to 37.5% faster RAM speeds than baseline DDR5 specs.* Built through a flexible training method, these profiles make it easy for you to tune your memory above baseline settings while maintaining stable system operation. With AEMP II, optimized memory settings are just a click away whether you’re getting the most out of an entry-level module or priming a high-speed kit for ultimate performance.
Software and hardware, working together
There are two kinds of PC builders: those who want detailed, granular control over their motherboard’s features, and those who’d be happy to let their system automate the details. Our Z790 motherboards cater to both categories of builders. Our UEFI BIOS lets you customize and fine-tune to your heart’s content—and our suite of exclusive AI-powered technologies lets you maximize your system’s performance with minimal effort.
The AI Overclocking options in our UEFI BIOS menu
It starts with AI Overclocking. Powered by exhaustive research and characterization of the performance potential of thousands of actual CPUs in our testing labs, this tool leads the industry for overclocking performance and ease of use. It boosts CPU clocks for both lightly-threaded and all-core workloads with just one click. AI Overclocking’s sophisticated intelligence also monitors the efficiency of your CPU cooler and changes in the operating environment of your system to tune its parameters over time for the best performance with your system’s unique set of components. You’ll have access to AI Overclocking on all our ROG Maximus and ROG Strix Z790 motherboards.
Our intelligent tech stands ready to optimize your cooling, as well. Many builders these days opt for higher-RPM case fans capable of moving large volumes of air. These fans are just the ticket for keeping high-performance components cool under load, but they can produce excessive noise when users are performing light tasks like reading posts online, browsing YouTube, or responding to email. To give you an easy tool for getting effective airflow under load and quiet operation during light tasks, we’re debuting AI Cooling II for our entire Z790 motherboard lineup.
When you first enable this tool though FanXpert in the Armoury Crate app, it uses a machine learning algorithm to gather data about your system during a brief stress test. From then on, AI Cooling II monitors your CPU and uses the data from its stress test to calculate the lowest fan speed required to effectively cool your system—while minimizing noise levels. This fan control system can reduce system fan noise by up to 5.7dB under sustained loads. Through this self-adaptive system, you’ll always have cooling power when you need it and quiet operation when you want it. We’ve also taken the opportunity to update FanXpert with our full set of fan calibration and control options. You’ll get temperature input mapping and fan response mapping, all inside Windows through the convenient Armoury Crate app.
Power to the core
As with previous generations of Intel chips, you’ll need a Z-series motherboard and a K-series processor to join the overclocking club. The robust power solutions on our Z790 motherboards stand ready to help you push your 13th Gen Intel Core CPU to the limit—and our complete thermal solutions keep it all effortlessly under control.
The AM6 socket on the ROG Maximus Z790 Extreme motherboard
We primed the ROG Maximus Z790 Extreme for the needs of enthusiasts chasing the next frontiers of PC performance. It boasts 24+1 teamed power stages rated for 105A that stand ready to deliver a stable stream of power to your CPU. Raw power makes its way into the board via ProCool II connectors. The solid pins in these connectors offer better contact with PSU plugs, improved heat dissipation, and better reliability over common hardware. Massive VRM heatsinks leverage the cooling air moving through your case to silently keep the circuitry at optimal temperatures, and a full complement of headers give you everything you need to set up the cooling hardware for your build.
The ROG Maximus Z790 Extreme boasts the mightiest power solution of our Z790 lineup, but every board in the family has undeniable credentials in the power department. The ROG Maximus Z790 Hero’s 20+1 teamed power stages rated for 90A are just a short step down from what its elder sibling offers. And if you’re shopping from our ROG Strix lineup, you’ll find VRMs and cooling solutions that are more than up to the task of unleashing your new Intel 13th Gen CPU.
Support for next-gen components and connectivity
Whether you’re a gamer eagerly anticipating the next generation of graphics cards or a creator eyeing up the dizzying transfer speeds promised by PCIe 5.0 SSDs, our Z790 motherboard lineup gives you the PCIe 5.0 connectivity you need to take advantage of cutting-edge hardware. Every board in our Z790 lineup features a PCIe x16 slot that’s fully validated to support PCIe 5.0 and ready for upcoming graphics cards—and our ROG Maximus Z790 boards offer two such slots. The ROG Maximus Z790 Extreme, the ROG Strix Z790-E Gaming WiFi, and the ROG Strix Z790-I Gaming WiFi all boast an onboard PCIe 5.0 M.2 slot ready for the fastest drives on the market. And support for NVME SSD RAID gives you powerful options for setting up a high-performance storage array.
The PCIe 5.0 M.2 slot with a heatsink on the ROG Strix Z790-E Gaming WiFi motherboard
Almost all our Z790 motherboards also support the latest DDR5 RAM. With data rates 50% faster than previous-generation DDR4 memory, DDR5 unleashes a new tier of performance, and our motherboards offer a host of hardware and firmware optimizations that enable users to overclock capable kits to the absolute limit. Since DDR4 is still a cost-effective option that provides sufficient performance for some builders’ primary workloads, we’re also offering the ROG Strix Z790-A Gaming WiFi D4. This board gives you the option to pair one of Intel’s latest 13th Gen CPUs with affordable last-gen DDR4 RAM.
For flexible, high-speed connections to your peripherals, you’ll find onboard Thunderbolt 4 ports on a wide range of our Z790 motherboards, and available headers so that you can conveniently set up a front-facing Thunderbolt 4 port on a compatible case. To give you a convenient, always-ready port to recharge your other devices, ROG Maximus motherboards let you set up a front-panel USB Type-C port with support for 60W Quick Charge 4+.
For too long, many people have suffered with unreliable wireless networking due to congested airwaves. In select regions, relief has arrived in the form of WiFi 6E, which takes advantage of the wide-open 6GHz band to allow your compatible devices and routers to communicate without interference. Every ROG Maximus and ROG Strix motherboard features a WiFi 6E radio—pair it with a compatible WiFi 6E router to take full advantage of everything it offers.
Hassle-free PC building
We love to watch the endless creativity and ingenuity of today’s professional PC builders and modders, but we’re just as excited to see everyday people building their first PC. We believe that no one should need a computer science degree to assemble a PC, and our engineers work tirelessly to make the process easy and straightforward. The exclusive ASUS Q-Design innovations across our Z790 lineup simplify and streamline the process of building and upgrading your PC.
The PCIe Slot Q-Release button on the ROG Maximus Z790 Extreme motherboard
Today’s cutting-edge graphics cards often have beefy cooling solutions and sturdy backplates. That’s great for performance—but they can get in the way of popping the PCIe release latch free. Our PCIe Slot Q-Release button lets you release your graphics card from the slot with one press, no fumbling or tiny fingers required.
Similarly, traditional DIMM slot designs require you to lock in both sides of the memory stick, and it wasn’t always easy for those of us with larger fingers to unlock the latch closest to the graphics card. That’s why we’ve also implemented our single-sided Q-DIMM latching design on all our Z790 motherboards. With this arrangement, you won’t have to worry about a latch that may be too close to your graphics card. A single latch on the easier-to-access side of the DIMM slot is all it takes to hold your memory stick firmly in place. Installing your RAM—and upgrading it down the road—is that much easier.
The M.2 Q-Latch tool-free system for installing M.2 drives
We’ve even simplified the process of installing an M.2 drive. Our M.2 Q-Latch gives you the peace of mind that you’ll never have to handle another tiny, easily lost M.2 screw ever again. Now, you can secure or loosen an M.2 drive with just your fingertips.  You’ll find the M.2 Q-Latch on every ROG Maximus and ROG Strix Z790 motherboard.
ROG Maximus takes no prisoners
With designs that exude confidence and feature sets that relentlessly push the boundaries of performance, ROG Maximus motherboards are the premier choice for gamers who want it all.
Our Republic of Gamers Z790 lineup starts with the unconquerable ROG Maximus Z790 Extreme. This EATX motherboard launches the series into the next generation with a feature set that accepts no compromises. The ROG Maximus Z790 Hero offers a one-two punch of top-tier performance and exceptional style for anyone building a high-end ATX gaming machine.
It only takes one glance to see that the ROG Maximus Z790 Extreme is a one-of-a-kind motherboard. Draped in sultry black heatsinks and covers, it exudes confidence. For unmatched personalization option, the AniMe Matrix display on the I/O shield lets you show off customized images and animations with its array of 222 individual LEDs. A series of angular slashes across the board's massive chipset heatsink reveals the iconic ROG “Fearless Eye.” The full-length shroud on the right edge of the board keeps headers and connectors out of sight so that your completed build will have a truly clean look.
The ROG Maximus Z790 Extreme includes LiveDash, a built-in 2-inch OLED panel that shows useful information and features customizable graphics. During the power-on, self-test (POST) phase, this display shows key stats in simple language using traditional POST codes. In normal operation, you can program the panel to show CPU frequency, device temperatures, fan speeds, or water-cooling information. You can also personalize the default GIF with an image or animation—and since this new generation of LiveDash is a full-color panel, you have a world of possibilities to choose from.
The rear I/O panel and WiFi antenna for the ROG Maximus Z790 Extreme motherboard
Every corner of the ROG Maximus Z790 Extreme boasts top-tier features. This motherboard features a massive 24+1 VRM topology with 105A integrated power stages ready to help you take advantage of the full overclocking potential of Intel 13th Gen CPUs. It offers both an Intel-powered 2.5Gb Ethernet port and a Marvell 10Gb Ethernet connector to give you access to the fastest local network transfers. Its high-end Intel AX411 WiFi 6E adapter gives you high-speed wireless connectivity over the wide-open 6GHz spectrum. Intel Double Connect Technology (DCT) enhances your WiFi gaming experience even further by simultaneously connecting over two bands and prioritizing traffic on whichever band is faster.
The ROG DIMM.2 add-in card
Today’s PC enthusiasts can’t get enough high-speed storage. The ROG Maximus Z790 Extreme’s large EATX layout gave us plenty of room to feed your desire for blazing-fast SSDs. This motherboard supports a total of five NVMe SSDs. An onboard PCIe 5.0 M.2 slot headlines the selection, and the board gives you plenty of room to grow with two onboard PCIe 4.0 M.2 slots and two more available through the ROG DIMM.2 add-in card.
The ROG Maximus Z790 Extreme motherboard with the ROG True Voltician oscilloscope tool installed
To support the efforts of enthusiasts working to extract the highest levels of performance from their hardware, the ROG Maximus Z790 Extreme also includes the ROG True Voltician. This bundled oscilloscope kit provides detailed analysis of the power circuitry on the motherboard. Once connected to your system, the oscilloscope system intuitively presents real-time voltage information on a separate system. It’s never been easier to collect the data you need for professional-level overclocking.
The ROG Maximus Z790 Extreme stands ready to serve as the hub of a powerful cooling system, as well. It has eight onboard fan headers, and the included ROG Fan Controller lets you easily add another six to the mix. Want to add some more lighting while you’re at it? Three gen 2 addressable RGB headers let you connect LED strips and coordinate them with the rest of your gear through Aura Sync.
Size EATX
Memory 4 x DDR5 up to 7200 (OC)
PCIe 2 x PCIe 5.0 x16 (@x16 or x8/x8)
1 x PCIe 4.0 x4
Storage 1 x 22110 (PCIe 5.0)
1 x 2280 (PCIe 4.0 x4)
1 x 2280 (PCIe 4.0 x4 & SATA)
2 x DIMM.2 22110 (PCIe 4.0 x4)
Networking 1 x Marvell® 10Gb
1 x Intel® 2.5Gb
Intel® WiFi 6E
Audio Realtek ALC 4082
ESS ES9218 Quad-DAC
Thunderbolt™ 4  2 x USB Type-C® ports
Rear I/O 3.2 Gen 2x2: 1 x USB Type-C®
3.2 Gen 2: 7 x USB Type-A, 1 x USB Type-C®
Front I/O 1 x Thunderbolt™ 4 connector (supports USB Type-C®)
3.2 Gen 2x2: 1 x USB Type-C® with Quick Charge 4+ (60W)
3.2 Gen 1: 4 x USB Type-A
2.0: 4 x USB Type-A
Aura Onboard: 3 x Addressable Gen 2 headers, 1 x Aura RGB header
ROG Fan Controller: 6 x Gen 2 addressable headers
Cooling Onboard: 8 x fan headers
ROG Fan Controller: 6 x headers, 2 x sensor
The ROG Maximus Z790 Hero’s aesthetic is a study in contrasts. Its sweeping black surfaces create a mesmerizing landscape of shadows and angles. Against this backdrop, the lighting in the PMMA nameplate stands out boldly. Exclusive lighting effects take advantage of the dual-layered lighting design that allows two different patterns to be displayed simultaneously.
ROG Maximus Z790 Hero gaming motherboard
An array of enthusiast-grade features perfectly complements the ROG Maximus Z790 Hero’s assertive style. Dual Thunderbolt 4 connectors at the rear panel stand ready to support next-generation peripherals at full speed, and next-gen Realtek audio paired with an ESS® ES9218 Quad-DAC for front-panel connections provides crisp, clear gaming audio no matter what headset or speakers you plug into your PC. Three Gen 2 addressable RGB LED headers and one traditional four-pin lighting header coordinate the illumination of your build perfectly with Aura Sync.
The AM5 socket on the ROG Maximus Z790 Hero motherboard
Hoping to overclock one of Intel’s top-shelf 13th Gen Core CPUs? The ROG Maximus Z790 Hero offers a 20+1 teamed power stage topology to power the CPU Vcore and onboard graphics processor. Each power stage is rated for up to 90A of output, and they provide the smoothest possible power delivery to the processor, even under the highest loads.
The ROG Hyper M.2 add-in card
The ROG Maximus Z790 Hero’s ample M.2 support gives you a wide array of options for building out a high-speed storage array. It starts with the bundled ROG Hyper M.2 add-in card, which lets you take advantage of the board’s second PCIe 5.0 x16 slot to install up to two M.2 drives—one PCIe 5.0 and one PCIe 4.0. On top of that, the board offers three onboard PCIe 4.0 slots ready to augment your storage space even further.
Size ATX
1 x PCIe 4.0 x16 (x4, x4/x4)
Storage 1 x M.2 22110 (PCIe 4.0 x4)
1 x M.2 2280 (PCIe 4.0 x4)
1 x M.2 2280 (PCIe 4.0 x4 & SATA mode)
Networking 1 x Intel® 2.5Gb
Intel® WiFi 6E
Audio ROG SupremeFX ALC4082 CODEC
Rear I/O 3.2 Gen 2: 5 x USB Type-A, 1 x USB Type-C®
Front I/O 3.2 Gen 2x2: 1 x USB Type-C® with Quick Charge 4+ (60W)
2.0: 4 x USB Type-A
Aura 3 x Addressable Gen 2 headers
1 x Aura RGB header
Cooling 8 x fan headers
ROG Hyper M.2 Card  1 x M.2 22110 (PCIe 5.0 x4)
ROG Strix motherboards deliver a potent blend of performance and style
ROG Maximus motherboards stand at the apex of our lineup, and ROG Strix boards take that basic DNA and offer it in more attainable designs that provide exceptional gaming performance and audacious style.
Each ROG Strix Z790 board carves its own path to gaming glory. Looking for a motherboard will give you access to the latest graphics cards and SSDs? The ROG Strix Z790-E Gaming WiFi offers a complete next-gen platform including both a PCIe 5.0 M.2 slot and a PCIe 5.0 x16 slot. The ROG Strix Z790-F Gaming WiFi gives gamers similar style, but with a different feature set that lets them get exactly what they need and nothing more. The ROG Strix Z790-A Gaming WiFi D4 dials up the contrast with its black PCB and glossy white heatsinks and shrouds. And for aficionados of small-form-factor builds, the potent and petite ROG Strix Z790-I beckons.
ROG Strix Z790-E Gaming WiFi and ROG Strix Z790-F Gaming WiFi
For builders itching to assemble a PC with the fastest graphics cards and SSDs of today and tomorrow, we offer the ROG Strix Z790-E Gaming WiFi. With its onboard PCIe 5.0 M.2 slot and PCIe 5.0 X16 slot, this motherboard is the flagship of the ROG Strix Z790 lineup—and it’s ready for anything.
Dark, moody hues and angular accents predominate across the surface of the ROG Strix Z790-E Gaming WiFi. For striking visual contrast with this backdrop, the I/O shroud features a large slash. This piece intensifies the RGB LED illumination from beneath. To make it easy to give your build a cohesive look, this lighting can be synchronized with the rest of your gear through Aura Sync.
High-end features round out this board’s spec sheet. Intel 2.5Gb Ethernet and Intel WiFi 6E give you exceptional wired and wireless networking performance. The Realtek ALC 4080 audio codec and Savitech SV3H712 amplifier serve up clear, bold sound in your games, entertainment, and media, and a Thunderbolt 4 header allows you to set up a versatile, fast connector in a compatible case.
ROG Strix Z790-F Gaming WiFi motherboard
The ROG Strix Z790-F Gaming WiFi shares much in common with its elder sibling. It boasts a robust power solution ready for even the mightiest CPU in Intel’s 13th Gen lineup. It offers a fleet of high-speed USB ports, fast Intel 2.5Gb Ethernet, and WiFi 6E. And it’s decked out in signature ROG style. But not every PC builder needs to be among the first to unleash a PCIe 5.0 SSD. For those who are content with what previous-gen drives have to offer, the ROG Strix Z790-F Gaming WiFi is a tempting choice.
  ROG Strix Z790-E Gaming WiFi  ROG Strix Z790-F Gaming WiFi
Size ATX
PCIe 1 x PCIe 5.0 x16 (@x16)
2 x PCIe 4.0 x16 (x4)
1 x PCIe 3.0 x1
Storage 1 x 22110 (PCIe 5.0 x4)
3 x 2280 (PCIe 4.0 x4)
1 x 2280 (PCIe 4.0 x4 & SATA mode)
2 x 22110 (PCIe 4.0 x4)
Intel® WiFi 6E
Audio Realtek ALC 4080
Savitech SV3H712 AMP
Thunderbolt™ 4  1 x header
3.2 Gen 2: 6 x Type-A, 1 x USB Type-C®
3.2 Gen 2: 2 x Type-A, 1 x USB Type-C®
3.2 Gen 1: 4 x USB Type-C®
2.0: 4x USB Type-A
Front I/O 3.2 Gen 2x2: 1 x USB Type-C® with USB Power Delivery 3.0 (30W)
2.0: 4 x USB Type-A
USB 3.2 Gen 1: 2 x USB Type-A
USB 2.0: 4 x USB Type-A
1 x Aura RGB header
As far as colors go, black never goes out of style, but it's good to consider options if you’re looking to stand out from the crowd. To support your passion for a white-themed build, we offer the ROG Strix Z790-A Gaming WiFi D4. The pristine surfaces of its heatsinks and shrouds provide a clean, timeless aesthetic—or a clean canvas to capture and magnify the RGB LED illumination of your build. It’s all up to you.
ROG Strix Z790-A Gaming WiFi motherboard
This motherboard also gives budget-conscious builders a cost-effective pathway to an Intel 13th Gen build. While it still boasts a PCIe 5.0 x16 slot ready for the next generation of graphics cards, it’s built for last-gen DDR4 RAM and PCIe 4.0 SSDs. If you’re content with what these components have to offer, the ROG Strix Z790-A Gaming WiFi D4 lets you pair them with one of Intel’s latest CPUs in a build that offers a compelling balance of style, performance, and value.
Size ATX
Memory 4 x DDR4 up to 5333+ (OC)
1 x PCIe 3.0 x1
Storage 2 x 22110 (PCIe 4.0 x4)
2 x 2280 (PCIe 4.0 x4)
Intel® WiFi 6E
2.0: 2 x USB Type-A
Front I/O 3.2 Gen 2x2: 1 x USB Type-C® with Quick Charge 4+ (30W)
2.0: 4 x USB Type-A
1 x Aura RGB header
Hoping to build a PC that doesn’t take up much desk space—or that fits neatly into your living room entertainment center? A Mini-ITX gaming rig is perfect for you, and the ROG Strix Z790-I Gaming WiFi is the perfect motherboard to get you started.
ROG Strix Z790-I Gaming WiFi motherboard
The moment you pull this motherboard out of the box, you’ll be astonished at the high-end feature set we’re able to offer in such a compact package. You’ll find all the headlining features of our Z790 lineup: DDR5 RAM support, a PCIe 5.0 x16 slot, and an onboard PCIe 5.0 M.2 slot ready for the fastest drives on the market. Our UEFI BIOS puts you in charge of the PCIe 5.0 x16 slot—will you run it in x16 mode for all-out graphics performance, or x8 mode to unlock the full potential of the PCIe 5.0 M.2 slot? It’s up to you. On top of all that, a pair of onboard Thunderbolt 4 ports give you versatile connectivity options.
Carefully designed elements streamline your build process, even when you’re building inside the tight confines of a Mini-ITX case. The I/O shield is pre-mounted for easier installation and a tidier fit around rear ports. The space-saving ROG FPS-II card gives you easy access to front-panel headers, 2 SATA ports, a T-Sensor header and a header for enabling CPU overvoltage, and a PCIe mode switch to give users versatile options for building their PC.
ROG Strix Hive external control interface for the ROG Strix Z790-I Gaming WiFi motherboard
The ROG Strix Z790-I Gaming WiFi also features the all-new ROG Strix Hive. This external control interface neatly addresses common challenges that PC builders face when putting together a compact Mini-ITX machine—and goes a step further by putting motherboard gaming features right at your fingertips.
The Hive houses top-shelf audio hardware—an ALC4050 codec and an ESS® Sabre 9260Q DAC, to be precise. A headset jack and optical S/PDIF out deliver pristine audio, while an integrated volume knob keeps you in control. But premium audio isn’t the only trick up the ROG Strix Hive’s sleeve. It offers a convenient USB Gen 2 Type-C port that makes it easy to connect external storage and peripherals. It includes our intuitive Q-LED array so that you can quickly diagnose build problems. A dedicated AI OC button allows you to enable AI Overclocking without taking a trip into BIOS. And you’ll even find physical FlexKey and BIOS Flashback™ buttons, as well. Building, updating, and troubleshooting a Mini-ITX PC has never been easier.
Size Mini-ITX
Memory 2 x DDR5 up to 7000+ (OC)
PCIe 1 x PCIe 5.0 x16 (@x16 or @x8 with PCIe 5.0 M.2)
Storage 1 x 2280 (PCIe 5.0/4.0 x4)
Intel® WiFi 6E
3.2 Gen 2: 3 x Type-A
3.2 Gen 1: 1 x USB Type-A
2.0: 2 x USB Type-A
2.0: 3 x USB Type-A
Aura 1 x Addressable Gen 2 headers
1 x Aura RGB header
Cooling 3 x headers
ROG Strix Hive  3.2 Gen 2: 1 x USB Type-C®
2.0: 1 x USB Type-A
Realtek ALC 4050
ESS® ES9260 Quad-DAC
Complete your build with ASUS PC DIY components
As a company, we built our reputation on the quality and performance of our motherboard lineup. But our product portfolio includes just about everything that you’d need to build a complete PC—from graphics cards to cases, from case fans to AIO liquid coolers, from power supplies to graphics card holders. And that’s before you consider our complete lineup of displays, peripherals, and wireless networking products. To build a PC with a cohesive, unified aesthetic, a PC that offers the legendary quality of our motherboards in every component, complement your ASUS Z790 motherboard with an array of parts from our other product families.
The ROG Strix GeForce RTX 4090 graphics card
Gamers and creators will be looking for a graphics card for their new Intel 13th Gen build, and we’ve got a large selection of options at the ready. Whether you need a cutting-edge graphics card with one of the best GPUs offered by our partners at AMD and NVIDIA, or whether you’re looking for an affordable entry-level model, we have what you’re looking for. Click here to learn all about the latest GeForce RTX 4090 and RTX 4080 graphics cards from ROG Strix and TUF gaming—or click here to learn more about all our different graphics card families.
youtube preview image
Looking for a little help getting started with your first build—or perhaps some inspiration for how you’ll design your next PC? Head on over to our PC DIY portal for insider info on our latest products, videos breaking down the process of building a PC, and recommended builds that make it easy to put together a complete shopping list. Assembling a PC is easier than you might think, and we’re happy to help you get started.
* The result may vary by the capability of CPUs and memory modules. Our results derived from a test with Intel RAPTORLAKE 13900K and SK HYNIX DDR5-4800 UDIMM n-ECC HMCG78MEBUA081N 16GBX2. Please ensure all memory modules are from a single validated kit. Do not combine DIMMs from multiple kits—even if they are the same make and model. Mixing and matching DIMMs can result in failure to boot and compatibility cannot be guaranteed. Always install DIMMs with the same CAS latency. For optimal compatibility, we recommend that you install memory modules of the same version or date code (D/C) from the same vendor. Check with the retailer to get the correct memory modules.
