Find Your Photo Here!
Why Do Gamers Choose OLED?
How ROG Stands Apart
Learn more about ROG OLED
Are you Team Matte or Team Glossy?
Does your gaming room have bright lights?
Do you prefer a reflection-free view?
Go matte.
Crave the deepest blacks and punchiest colors?
Glossy is your game.
TEAM MATTE
TEAM GLOSSY
ROG OLED gaming monitors come in both matte and glossy panels—so you can tailor your visual experience to your exact preferences, regardless of ambient light. Your game, your way.
Find the OLED monitor that best suits you
Comparison Table
Awards
FAQ
  • An OLED (organic light-emitting diode) monitor uses a revolutionary display technology in which each pixel generates its own light. Unlike traditional LCD panels with backlighting, OLED monitors deliver exceptional contrast, with true blacks and vibrant colors. This results in stunningly realistic visuals and a more immersive gaming experience, giving you a competitive edge.
  • The main difference between OLED and LED monitors lies in their underlying technology. OLED monitors use organic light-emitting diodes to directly emit light and produce imagery, enabling individual pixel control for superior contrast and color accuracy. On the other hand, LED monitors use traditional light-emitting diodes for backlighting, relying on liquid crystals to modulate the light. This fundamental distinction results in OLED monitors offering better image quality compared to LED monitors.
  • Yes, OLED monitors are ideal for gaming: lightning-fast response times, exceptional contrast, and vibrant colors provide a competitive advantage by delivering incredibly smooth, clear, and immersive visuals.
  • OLED monitors offer features that make them a preferred choice for discerning gamers:
    • Unrivaled Contrast: Infinite contrast ratios with perfect blacks ensure incredible depth and detail in every scene.
    • Blazing-Fast Response Times: Near-instantaneous response times virtually eliminate ghosting and blurring, offering ultrasmooth gameplay.
    • Vivid Colors: Wider color gamut and exceptional color accuracy brings games to life with stunning realism.
    • Wide Viewing Angles: Consistent image quality from any viewing angle makes OLED monitors perfect for screen sharing or multi-monitor setups.
    • Glossy OLED: Sharper imagery with more saturated color reproduction.
    • Sleek Design: Absence of a backlight allows for incredibly thin and lightweight design.
  • Focus on these key features:
    • Speed (Refresh Rate & Response Time): For smooth gaming, aim for high refresh rates (e.g., 144Hz+) and near-instant response time for zero blur.
    • Sharpness (Resolution): 4K offers amazing detail, while 1440p is a great balance for visuals and gaming performance, especially if your PC isn't top-tier.
    • Picture Quality (Panel Type): Most current QD-OLED and WOLED panels deliver incredible colors, true blacks, and brightness for stunning visuals.
    • Burn-in Protection: While burn-in is rare with normal use, check for features like pixel shifting or screen refresh cycles that help prevent burn-in.
    • Connections (Ports): For the best performance, ensure it has the latest ports, such as DisplayPort 2.1 (for PC) and HDMI 2.1 (for consoles).
    • HDR Quality: For vibrant, lifelike imagery, look for high peak brightness and official HDR certifications (e.g., DisplayHDR True Black).
    • Warranty: A strong warranty―especially one that covers burn-in―will protect your investment.
  • Both QD-OLED and WOLED are cutting-edge OLED technologies that deliver stunning visuals, but a primary difference lies in how they create color. Both are self-emissive OLED technologies that deliver perfect blacks and infinite contrast.
    • QD-OLED (Quantum Dot OLED) uses a blue light source and a layer of Quantum Dots to produce highly saturated, pure red and green light. This generally results in superior color volume and vibrancy at high brightness.
    • WOLED (White OLED) uses a white light source with traditional color filters (RGBW subpixels). This technology is highly refined and often excels, providing peak white brightness and better deep black uniformity in bright, well-lit rooms.
  • The primary difference lies in the arrangement of the sub-pixels and the resulting text clarity and color accuracy.
    • RGB Stripe Pixel OLED (RGB OLED): Each independent pixel contains Red (R), Green (G), and Blue (B) sub-pixels arranged in a vertical stripe pattern. This standard arrangement is highly compatible with operating system text rendering technologies (like Windows ClearType), resulting in sharper, more accurate text display.
    • Non-RGB Stripe Pixel OLED: Sub-pixels are arranged in nonstandard patterns (i.e., diamond shapes or irregular layouts). While excelling in color and brightness, this nonstandard arrangement can sometimes introduce a slight color fringing or fuzziness around sharp or small text, as it doesn't align perfectly with standard RGB rendering algorithms.
  • Both are ROG advanced surface treatments designed to maximize the contrast and black depth of OLED panels, but they are applied to different panel types and offer distinct benefits.
    • TrueBlack Glossy™ employs a zero-haze optical layer combined with an anti-reflective stack. This results in a superior glossy finish that makes the image and colors appear sharper and more saturated, dramatically boosting contrast to achieve deeper blacks. Crucially, this advanced optical layer helps to significantly reduce ambient reflections, allowing users to experience inky blacks and sharp visuals regardless of whether they are in a brightly lit or dark room.
    • BlackShield™ is a new, specialized film engineered specifically for QD-OLED panels. Its primary function is to correct the purple tint/black-level elevation that previous QD-OLED generations displayed in bright ambient lighting environments. By doing so, it provides a 40% improvement in perceived black level, allowing users to experience much higher contrast and deeper blacks, even when light is present. An additional benefit of this film is its enhanced durability, offering 2.5-times the scratch resistance compared to previous-gen QD-OLED panels, which provides greater confidence when cleaning the screen.
  • While OLED technology can be susceptible to burn-in with prolonged static images, ROG OLED monitors incorporate advanced OLED Care Pro technology including Neo Proximity Sensor, Pixel Cleaning, Pixel Shift, Screen Saver, and more to mitigate this risk. (Learn more about ROG OLED Care Pro.) Additionally, each package includes a micro fiber cloth to assist users in safely cleaning their OLED screen. These features and a three-year warranty provide peace of mind when purchasing any ROG OLED gaming monitor.
  • The ROG Neo Proximity Sensor is a key feature within the ROG OLED Care Pro suite, designed to provide active protection against burn-in. It is an intelligent hardware solution used to precisely detect the user's presence in front of the monitor. The feature is fully customizable via the OSD menu, allowing users to easily adjust the detection distance to perfectly suit their personal workspace and preferences.
    Key Features
    • When the user steps away from the monitor, the screen automatically transitions to a pure black image, effectively turning off the OLED pixels. This provides the highest level of burn-in protection.
    • When the user returns and is detected by the sensor, the screen instantly restores the previous content.
  • Yes, ROG OLED monitors are excellent for professional color grading due to their exceptional color accuracy and wide color gamut. ROG OLED monitors are factory calibrated to meet industry standards, making them ideal for content creators, video editors, and graphic designers who demand precise color reproduction.
  • ROG OLED monitors are available in a range of sizes to suit different gaming setups and preferences. Common sizes include 27 inches, 32 inches, or 34 inches (ultrawide). Refer to the ROG website for the latest models and available sizes.
  • Yes, 4K OLED gaming monitors are available and they offer incredible visual fidelity and detail. Refer to the ROG website to see the full range of 4K ROG OLED options.
  • Keeping your OLED monitor clean will ensure optimal image quality and longevity. Here's how to clean it safely:
    • Power down: Turn off your OLED monitor. This prevents electrical shock and potential damage to the screen.
    • Clean the screen using a damp cloth: Dampen a cloth with water and gently wipe the screen in a circular motion.
    • Avoid chemicals: Never use harsh chemicals, abrasive cleaners, solvents, alcohol, ammonia, or window cleaners on your OLED screen. These can damage the delicate OLED panel and its coating.
    • Avoid pressure: Do not apply excessive pressure to the screen while cleaning, as this could damage the OLED panel.
ROG Footer
