Versatility that Elevates Any Setup
Together, We're Stronger
The ROG Certified Program highlights select high-performance memory modules that ROG engineers have subjected to rigorous testing and validation to confirm compatibility with ROG motherboards. Through close collaboration with trusted hardware partners, only products that meet ROG's strict standards for quality, performance, and stability earn the ROG Certified designation. This gives gamers and PC builders greater confidence that their components will work together smoothly to deliver a reliable and optimized ROG experience.
FAQ
  • The ROG Certified Program highlights select DRAM products that have undergone rigorous testing and validation by ROG engineers. The program ensures these components meet ROG's strict standards for compatibility, stability, and performance with ROG systems.
  • If you would like your DRAM products to become ROG Certified, or if you have any questions or ideas regarding DRAM participation in the ROG Certified Program, please email us your product proposal at ROG_Certified@asus.com.
    ROG reserves the right to determine the eligibility of ROG Certified partners and products.
  • ROG Certified products are available through online and retail stores worldwide. Availability may vary by region; purchase, warranty, and service terms are determined by each partner brand.
  • All ROG Certified products bear a clearly identifiable logo on both the product and its packaging. The latest official ROG Certified logos are shown below:
  • Many ROG Certified products will also carry the Aura Sync logo, signifying complete readiness for Aura, the ASUS-exclusive RGB-lighting technology. Aura Sync is an assurance that a product has been tested for best compatibility with the onboard RGB header(s) found on many ASUS/ROG motherboards, enabling the synchronized display of stunning illuminated effects. When a product is both ROG Certified and confirmed to be compatible with Aura RGB lighting, both the ROG Certified and Aura Sync icons will be displayed.
ROG Footer
