ASUS ROG Zenith EXTREME NVME Raid 0
Juggalo23451
Hello Everyone,
My end goal is to setup raid 0 for my two 500gig EVO NVME drive. I am using the 902 bios
Here is what I have done so far after some research.
Launch CSM: Enabled
Boot Device Control: UEFI Only
Boot from Network Devices: UEFI Driver First*
Boot from Storage Devices: UEFI Driver First*
Boot from PCI-E Expansion Devices: UEFI Driver First
Advanced tab AMD PBS setting and change it to Enable NVME RAID
I am see conflicting information as in to set up sata as RAID from amds website then I see in some cases not to.
I can See the AMD RAIDXpert2 RAID Management Utility
From their I am just wondering if I need to delete the array then assign the drives individually to raid 0?
Am I missing anything?
16 REPLIES 16
Juggalo23451
Arne_Saknussemm
Level 40
Maybe take a look at this video...BIOS options should be the same I guess
Options in ASUS UEFI seems to marry up with video.
OP check out the section NVMe/SATA RAID in OP of this thread, there is a larger PDF within AMD SW (links/info there).
Intel Defector :eek: AMD Rebel
R9 5900X - Custom WC - ASUS Crosshair VII Hero WiFi - Ballistix Sport LT 2x16GB 3800MHz C16 - RX 6800 XT - WD SN770 2TB - 2x 870 EVO 4TB
24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
:eek: CPU Validation 5.198GHz@1.314v with 4.4GHz cache + RAM 2400MHz@1T :eek:
Da Music video
I was able to get raid 0 setup :). Now I am trying to figure out if it would be best to user Asus or AMDs raid drivers and chipset before installing windows. I will be using the f6 method
gupsterg
I'd opt for AMD 😉 . I also just fixed the links in that OP section to Flaxen Hegemony post, which has testing on ASUS RAM Cache II, do take note of Ljugtomten's post as well.
Da Music video
That is what I was thinking is to use AMD instead of ASUS
gupsterg
You'll find latest ones will always be on AMD site, ASUS site may or may not update later. I tend to always get drivers from manufacturer of xyz if you get what I mean.
Da Music video
I also noticed nvme driver are more recent here
https://support.amd.com/en-us/download/chipset?os=Windows%2010%20-%2064
compared to
https://support.amd.com/en-us/kb-articles/Pages/NVMe-RAID-Support-for-the-AMD-Ryzen-Threadripper-pla...
gupsterg
Yes, that is highlighted in the OP section on OCN 🙂 and I would use the later drivers 🙂 .
71872
The reason the KB link has been kept there is as it has extra info, which the driver page does not.
Da Music video
