W10 clean installer - G752VL
Azraine
Dears,
Trying to install from my recovery usb pen my w10, during the reinitialisation issue i always get a critical exit error.
Any one knows from where i can get a new system install with the original tools and drivers ? Thanks.
Clintlgm
Level 14
You would have had to image your hard drive/SSD or recovery partition. A windows reset would have restored your notebook back to factory original.
If you still have a copy of your support folder you have al the drivers and software in there.
With out any of this you'll need to download drivers and software from Asus Support
The Download the latest win 10 build and create an USB install media using the MCT Use GpsDx guide to clean install in UEFI mode.
that should solve all your issues.
G752VY-DH72 Win 10 Pro
512 GB M.2 Samsung 960 Pro
980m GTX 4 GB
32GB DDR 4 Standard RAM
Z97 PRO WiFi I7 4790K
Windows 10 Pro
Z97 -A
Windows 10 Pro
Azraine
Thanks but in the batch there is no Gamecenter for the G752vl.
