HWMonitor TMPIN2, TMPIN6 and TMPIN8
razsnavi
Mobo: ASUS B150i Pro Gaming/Aura
Procie: Intel Core i5 6500
PSU: TT SmartSE 530W
Good Day,
Am I supposed to worry about these Temp Sensors?
Tried to run 10min. Prime95 Test (maximum heat)
PC doesn't seems to have problem though..
I'm just curious if what those sensors are about..
74869
Thank you,
4 REPLIES 4
kkn
Level 14
are you running multiple monitoring programs?
ahmm.. ASUS GPU Tweak and MSI Afterburner (just for frame rates display)
kkn
Level 14
the more monitoring programs you have, the more miss readings you will have.
have you updated the bios?
was this temp diffrencial the same as before last bios update/ program instal ( of some kind )?
i have that high readings too and im not using any other programs.
