02-05-2012 12:39 AM - last edited on 03-06-2024 09:49 PM by ROGBot
02-05-2012 04:07 AM
02-05-2012 06:52 AM
Makaizen wrote:
When the battery is at 100% charge, I only get about 1 hour 30mins of battery life on power saver at idle. I looked around the internet and most reviews had at least 2 hours.
According to HWiNFO, the battery has a 2.8% wear level which I don't think should be a issue.
I did notice that the battery that came with the PC had scratches and the production date was August 2011 so could it possibly lost some of its life over the months?
02-05-2012 09:53 AM
fuzon1337 wrote:
Hi
Which notebook do you have?
This depends what you're using your notbook to, if you are on battery saving and uses a lot of programs, then the battery would drain fast.
If your notebook is almost idle at the time it is in battery saving, then it sounds like the battery it self is going to be weak, as you're saying: "production date was August 2011 so could it possibly lost some of its life over the months"
How is it with the latest updates for your notebook? Is it up to date or are many of the hardware not updated?
fostert wrote:
Yeah, my battery for my G74 only gives me ~90 minutes or so. Wear level 3%. I've never tested it fully though with the wireless off (they consume alot of power), no peripherals, KB backlight off, and the screen brightness turned all the way down, to see what the absolute max is.
This is a desktop replacement, and as such is never meant to be away from the wall for long.
02-05-2012 10:05 AM
02-05-2012 02:26 PM
