HELP AURA NOT SYCNING TO MY montior
skins
I have a pg27vq and I prime z370a motherbored and the aura sees my mother bored but the vq ??
Silent_Scone
Super Moderator
Make sure to go onto the panels OSD menu and enable Aura.
Open OSD menu -> System Setup -> Aura Sync -> ON
Secondly, make sure the USB 3.0 cable is connected.
You may need to reinstall Aura and retry before the panel appears.
SexyTerrorisT
Asus aura used to be able to detect my monitor but it can't anymore. Have removed and updated everything many times. Onyl solution now seems format?
