Safe Gaming Motherboard Temps? (STRIXz270F)
INDIVIDUUM
Hey Guys,
i was wondering how much degree would be usual for a Mainboard?
Right now i get 30C when idle and up to 40C when Gaming.
CPU between 60-65C
GPU at 60C
Now i wonder if the Motherboard actually gets that warm since it cools down way too fast when shutting down a Game,
could it be false reading by the Sensors and be the GPU Heat flowing over it?
Arne_Saknussemm
Level 40
That sounds normal. It depends exactly where the sensor is ...and what is classed as "motherboard". If it's the PCH or a sensor near the CPU socket etc.
HiVizMan
Level 40
As Arne says - different monitoring software label sensors differently. Use only one software to monitor your PC please. More than one application running at a time can give you messed up readings.
