Page 32 of 36 FirstFirst ... 22 30 31 32 33 34 ... LastLast
Results 311 to 320 of 356
  1. #311
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2721DE
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 980 Pro
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    111
    1,648
    Quote Originally Posted by LiveOrDie View Post
    I don't think this IHS is transferring the heat as well as a stock IHS, I think i might test the stock IHS or just put the copper one back on, I got idle temps of 20c and lower on the copper IHS 29c is the lowest idle i see.
    Ah yes weird, Rockit Cool told me that in "general", with the IHS copper we could win up to 6°, and can be up to 5° with the IHS Nickel compared to the original IHS
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 980 Pro
    SOUND: Asus Xonar Phoebus
  2. #312
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 11 Insider Preview
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    40
    1,685
    Quote Originally Posted by tistou77 View Post
    Yeah right now temps are about the same as a soldiered 9980XE so the plating might be a issue, Ill be testing soon so ill report back.
  3. #313
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    LiveOrDie's Avatar
    Dec 2011
    40
    1,685
    Same OC with copper IHS hands down the nickel is crap lol, it can't transfer heat no were as well as the copper IHS.
  4. #314
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    111
    1,648
    It is the values with the Nickel ?
    You could put the screen with Nickel and Copper that I get an idea ?
    Case: Lian Li A77F
    CPU: i9 10980XE
  5. #315
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    LiveOrDie's Avatar
    Dec 2011
    40
    1,685
    Sure hows this both tests done with the same room temp and 5 runs of cinebench.
  6. #316
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    111
    1,648
    Thanks
    Gray is for Nickel and Orange for Copper ?
    It's odd, I saw that the IHS Nickel is still not on sale on the site Rockit Cool, you bought it directly by the support ?
    Case: Lian Li A77F
    CPU: i9 10980XE
  7. #317
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    LiveOrDie's Avatar
    Dec 2011
    40
    1,685
    Thanks
    Yeah Orange for Copper and I emailed them about one and ordered it that way, looking at the temps there are some cores with up to 8c difference on a high overclock that 8c really maters, maybe they should of just plated the bottom part might be worth seeing if sanding the top off helps.
  8. #318
    tistou77 PC Specs
    MonitorDell U2721DE
    CaseLian Li A77F
    tistou77's Avatar
    Apr 2012
    111
    1,648
    I hesitate to test the IHS Nickel by seeing your tests
    Case: Lian Li A77F
    CPU: i9 10980XE
  9. #319
    ROG Guru: Orange Belt Array Abaidor PC Specs
    Abaidor PC Specs
    Processori9-7940X
    Memory (part number)F4-3600C17Q-64GTZR | Trident Z RGB 64GB
    Graphics Card #1Asus Strix 1080Ti OC
    Storage #1Samsung 960 Pro 512GB
    Storage #2WD 10TB Gold
    CPU CoolerEK Rampage VI Monoblock
    CaseC0smos 2 Modded
    Power SupplyCorsair AX1500i
    Abaidor's Avatar
    Dec 2017
    12
    264
    If only I could safely sand the CPU die to make it perfectly flat I am 100% sure I could totally end temp discrepancies between cores once and for all but I don't want to damage the CPU.
    Anyway, my last attempt with 14X48 Cores @ 4.8Ghz is still working so I have to say that I am done with this platform on the CPU side until something really new comes out (i.e. DDR5, PCI-E 4/5). I could always get an 18 Core CPU but it is not "cores" that my workflow is lacking - I would like even higher clocks or higher single core performance.
    I will build a second "backup" machine with a 9900K after I see what Zen 2 is all about. I already got the Case + PSU + several watercooling parts and will leave MB/CPU/RAM for the end.
    My monoblock is sitting tight and clean in its box until I figure out what to do with it (decorative item)...at least I am still using the Aquantia chip heatsing from it and will soon use it's RGB strips one of which is addressable (lol @ Aura with this though).
    Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
  10. #320
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    LiveOrDie's Avatar
    Dec 2011
    40
    1,685
    Quote Originally Posted by Abaidor View Post
    I sanded my 7980XE die a few months back it did help drop some of the higher cores down guessing these are the ones that are lower and have less contact, I used 2000 grit wet sand paper as long as you take your time there is no risk just don't sand down to far and you be fine, the lowest point i stop at just to be safe, I took the risk but ill rather have stable temps so I think it was worth the risk.
